Is there a "good" electric pressure washer?
   / Is there a "good" electric pressure washer? #11
I recently bought the AR Blue Clean AR383. It's awesome, easy to use and is definitely recommended by me.
   / Is there a "good" electric pressure washer? #12
We use a pressure washer quite a bit and got tired of the noisy gas engines, running out of fuel, broken pull ropes, etc. We bought a 3-phase 5 HP commercial unit that hangs on the wall and has auto on/off. I wish I would have bought this years ago, however it isn't portable and cost about $2500. So there are really good electric pressure washers, but most of the consumer grade electric units have a really light duty cycle and short lifespan I suspect. I'd think you will be well over $1k to get a decent small electric washer. Ours was bought from bepressure.com and has been flawless. They do make them in single phase portable models.
   / Is there a "good" electric pressure washer? #13
I initially had a Karcher from HD or some such - gave it away to a friend for free, when I moved (it was almost worthless). I ended up with an electric power washer from Northern Tool. This a high quality unit - same components as the gas engine pro tools except it has a 20 amp electric motor. You do need to have 20 amp power where you use it, but I can manage that for what I use it for, and the convenience of not having to maintain yet another gas engine is worth it.
   / Is there a "good" electric pressure washer? #14
Ive had just about all the electric models up to 2000 psi, my basic opinion of them is they are all POS's. Some lasted longer than others but none went past a year and a half of light duty use. My current electric one with i bought at TS says briggs and stratton 1800 psi on the it but i dont know who actually makes it, its been going now a little over a year except one of the wands broke a couple weeks ago. I know all mine have been cheap (under $200) but I would be afraid to spend big bucks on one.
   / Is there a "good" electric pressure washer? #15
I have had mine for over ten years, still going strong. I don't recall any longer what it cost, but it was up around $1K or so. It is rated about 3000 psi I think. My conclusion is you can get a real pro power washer that is electrically powered, single phase. However they are mostly sold to contractors who move around a lot for different jobs, hence most pro units are gas powered.
   / Is there a "good" electric pressure washer? #16
I have a Kracher, K5, I think, from WallyWorld. Had it about 3 years, extremely happy with it. Much more convenient than my 10 yo, 3000 psi, Porter Cable gasser, currently in shop awaiting new carb.
David Sent from my iPad using TractorByNet
   / Is there a "good" electric pressure washer? #17
Are their good electrics? Yes. Are they cheap? No.
I have a Princess Auto built electric. American motor, Comet pump(? current model has comet, but I thought mine was AR). http://www.princessauto.com/pal/en/Electric/18-GPM-At-1200-PSI-Electric-Pressure-Washer/5790114.p Probably close to 15 years old now. No problems besides occasionally overloading and tripping breakers. Not a fault of the washer in any way though.
The PA unit replaced a consumer grade Kartcher that lasted only about 2 years.
   / Is there a "good" electric pressure washer? #18
....I'd think you will be well over $1k to get a decent small electric washer.
Maybe not "well over" -- if you are looking for a well-built, repairable, unit for general use they are priced right at $1k now. My 20-amp Cam-Spray is rated at 1450 psi, and I paid $890 for it in 2009. It's now offered a just over $1000. It's clearly comparable to the smaller gasoline-powered units, without, as others mentioned, the need to maintain another engine. As long as you intend to use it within reach of electrical power it's a very good option for those of us who don't find small engine maintenance to be fun.
Terry
   / Is there a "good" electric pressure washer? #19
Terry
You guys must not need the power that I do. I think my first and only electric was 1600 PSI and it took forever to clean my concrete patio slab because you had to have the nozzle right on the concrete to clean it. I have a 2400 PSI gasoline powered one and many times wish for a 3000 PSI. About the only thing you can clean with 1400 psi might be dust off a smooth floor. I would just as soon use a garden hose as use something that low pressured. Anything less than 2200 is a waste of effort. That is just my opinion and you know what opinions are just like____________ and everyone has one.
   / Is there a "good" electric pressure washer? #20
Our electric is 4 gpm and 2000 psi. Works about as well as our old Honda powered gas unit. Perhaps a little less pressure, but it is hard to tell. I really like the auto on/off. Just pull the trigger and it starts in less than 2 seconds. Let off the trigger and it continues to run for a few seconds, then shuts off if the trigger isn't pulled right away again.
Landhonor HD Wheel Balancer (A59814)
Landhonor HD Wheel...
2018 Ford F-550 4x4 Altec Forestry Chipper Bucket Truck (A59230)
2018 Ford F-550...
2015 Freightliner 122SD T/A Wet Kit Day Cab Truck Tractor (A59230)
2015 Freightliner...
2016 INTERNATIONAL PROSTAR TANDEM AXLE DAY CAB (A59904)
2016 INTERNATIONAL...
GMC 2500HD 4wd Service Truck (A56438)
GMC 2500HD 4wd...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
