Loader B-2620 FEL won't curl or dump
   / B-2620 FEL won't curl or dump
Just as an FYI, I pulled off the shroud covering the valve assembly and there is nothing visibly wrong with the control rods. Like the dealer said, there have been other cases he has had with the same valve arrangement. I get the feeling that when I called they knew what the answer was. Other than this relatively small problem I really like the tractor. It does everything that I ask except washing dishes!
   / B-2620 FEL won't curl or dump #12
Did you work the lever while the cover was off and watch the assembly? As I remember, the rods can just slide through the linkage if the nuts are loose. It has been a while for mine so I am a little rusty on how it looked, but I am glad the dealer will fix it free and fast.
I did ask nicely and said please but just like my wife, she did what she wanted to!!!
Tractor is home with whole new valve assembly not just a rebuild. Kubota is standing behind equipment....NO CHARGE for valve, labor or pickup and delivery. Wife has idea that 20 yds topsoil needs to be applied, smoothed, and then seeded this weekend! Just in time!
   / B-2620 FEL won't curl or dump #16
Oooo! Can I help? Pick me, pick me!!!!
   / B-2620 FEL won't curl or dump #17
Yanmar EX450: I was pushing brush into a pile when the loader bucket stopped curling. Thanks to this forum, I discovered that one quick disconnect had separated by only about a quarter-inch. I reseated this connector and the problem went away.
2006 USH BOAT & 2012 TL (A56859)
2006 USH BOAT &...
2014 Ford Fusion Sedan (A56859)
2014 Ford Fusion...
2018 Ford Fusion Hybrid Sedan (A56859)
2018 Ford Fusion...
2022 Brush Wolf ALPHA-XP Skid Loader Brush Cutter (A56435)
2022 Brush Wolf...
2007 Sterling L9500 (A55973)
2007 Sterling...
2007 Ford E-350 Passenger Van (A55973)
2007 Ford E-350...
