Skid steer Brush Cutter
/ Skid steer Brush Cutter #1
Cooter Brown
Need one for my machine. It's low flow so I do not need a super heavy duty cutter. What is a good quality budget minded cutter?
/ Skid steer Brush Cutter #3
what size machine are you running? I've been happy with the brushcat from Bobcat but it's heavy. I do like it's float arms and the rollers but they are not necessary in many applications. Depends on how nice you want things to look. If you want to mow lower to the ground, don't get a mower with rollers.
I've been running a skid steer mower since 1998 and have owned three brushcats and another brand.
/ Skid steer Brush Cutter #4
Good quality, low flow, is super heavy duty, good design with the height adjustable front wheel and hinged SSQA plate, but unfortunately not budget friendly.
This one is 7' wide.
Skid Steer Rotary Brush Mower
Here is the guy I got mine from: http://www.phiferequipmentsales.com/blog/products/rotary-mower/
/ Skid steer Brush Cutter #5
I would hazard a guess that the OP is running a Tak TL140. So it should be able to handle the Brushcat fine.
/ Skid steer Brush Cutter #6
The Brush Buster comes to mind. B Built Skidsteer Attachments
I've only run it for a couple of hundred hours, but it works pretty good on material up to 3" or so. The only downside is the lack of a push bar to protect the front edge, but that's easily added.
/ Skid steer Brush Cutter #7
I used the Bush Hog model and ended up buying this: Skid Steer Direct Drive 6' Rotary Cutter
It's galvanized, cuts in both directions, so virtually impossible to jam and it will cut vertically.
I don't like the front push bars, as branches and debris falls over the top and you end up with a tangled mess on top of the cutter.
Thanks guys for the info. Still have not decided.
/ Skid steer Brush Cutter #9
Good quality, low flow, is super heavy duty, good design with the height adjustable front wheel and hinged SSQA plate, but unfortunately not budget friendly. Maybe not so bad after all! :laughing:
View attachment 333027 View attachment 333028 View attachment 333029 View attachment 333030
Here is the guy I got mine from: Tree Terminator - Rotary Brush Mower for Skid Steers
After looking at some of the others, the price on mine isn't too bad! Did you watch the video? The Tree Terminator: rotary brush and grass mower - YouTube
I should mention that it cuts in both directions. I use normal for brush and trees and reverse rotation for grass and weeds.
I like this design, with the front wheel carrying half of the weight and the hinge so it doesn't bounce the machine, the best that I have seen.
Have been using it mostly on the Toolcat now.
2017 Ford F-250 4x4 Crew Cab Pickup Truck (A64556)
2017 Ford F-250...
2104 (A65055)
2104 (A65055)
2015 Chevrolet Tahoe SUV (A64557)
2015 Chevrolet...
2014 FREIGHTLINER CASCADIA 6X4 T/A DAY CAB TRUCK TRACTOR (A67148)
2014 FREIGHTLINER...
1526 (A65054)
1526 (A65054)
2017 HINO 195 4X2 S/A  16FT BOX TRUCK (A67147)
2017 HINO 195 4X2...
