Made in China quick couplers
/ Made in China quick couplers #1
Grn mtn boy
Vermont
Kubota L3830 GST with R4s and a Woods LC108 loader / John Deere 1025R with 7 Iron deck
So I bought some "cheap" quick couplers for my third function from a vendor that advertises here on TBN. I bought the rest of the stuff (valves, hoses, fittings) from another advertiser here on TBN. Today was the first time I've had the grapple off my tractor since I complete my install last week. I hitched on to my finish mower and started to mow my fields. I noticed a constant drip on one of the quick couplers out front. Stopped, wiped it out and continued mowing. It wasn't very long and it was leaking again...I guess I've got a bad QD, so I disconnected that line up by the valve (I put QD there so I can disconnected from my loader) so I don't drip oil all over my field. I be an sob that one leaks too! So at lunch I called the vendor and explained by situation. He was less than sympathetic.
What's the verdict on these import QDs? Anyone else had trouble?
/ Made in China quick couplers #2
We export scrap to china and then import it right back.
Yeah I'm aware that they're not up to the quality of say a Pioneer QD. I took a chance and it didn't work out. The vendor tells me that they need to be rinsed out because there's some debris in the coupler. He said they see it all the time. I'd of thought the fluid would have done it but he says no, not enough volume to rinse it out. So I guess I'll take them off and rinse them out per his instruction. If I send them back and they deem them OK then they ship the same one back and charge me for shipping. Thats why I was asking if anyone else had issues.
/ Made in China quick couplers #4
/ Made in China quick couplers #5
Don't know why that double posted. Did you try connecting and disconnecting a couple times? Maybe it has debris on sealing surface. I know with air line qd they are just about useless.
Yes I did. I'll play around with a bit tomorrow maybe. I'll report back and let you know what I find out.
/ Made in China quick couplers #8
I can say one thing for sure: if I had a response like that from a vendor, I would never order from them again. Curious to see how it works out.
/ Made in China quick couplers #9
You might be surprised as to how much of our parts are made overseas.
Do the parts say made in China.
What is the brand name on the QD's
You can test them by applying flow to an unplugged QD. Test both sides. If it is in the cyl circuit, just unplug and give the lever a quick jolt, or hold the lever util the relief valve activates.
Are you plugging the same brand into each other. Some QD's will have balls,and some will have poppets.
/ Made in China quick couplers #10
Those things are pretty simple. I recommend you disassemble them and fully inspect and clean them. Hopefully the problem will be apparent and if it's debris you will be done and if it's a defect you can send a pic and the vendor should be satisfied and send replacement parts.
The Buyers brand that Northern used to sell were pretty much junk but I made them work. Tractor Supply has a pretty good price on Pioneer couplers and I have had good luck with them. The hoses going to my backhoe tend to want to twist in operation which was destroying o-rings until I ordered a pack of square double-seal o-rings from McMaster-Carr.
I bought them as a matched set. They are both ball type QD's. I'll have to look for the name on the QD's tomorrow.
As a side note: are poppet and ball type QD's compatible? The reason I ask is I put three rear remotes on my Kubota L3830 and the are poppet style. The QD's in question are two sets for my third function / grapple.
/ Made in China quick couplers #12
They are suppose to be, but I found that about 15% of them were not. Now that is with poppet female ends and ball male ends. Don't know for sure about the other way around, but I have had zero problems since I now only sell the poppet type ends. ;)
/ Made in China quick couplers #13
From my somewhat limited experience I've learned that the ball type QD's leak when they're disconnected because they seal metal to metal, they don't have an o ring that seals against the ball. Some are worse than others because of quality of machining. The poppet type I've seen have an o ring, can't remember if it's on the poppet or seals against the poppet, and they don't leak.
/ Made in China quick couplers #14
If the ones you have keep leaking, they can probably be fixed pretty easily. Take them apart and put the end with the ball down on a steel plate with a hole in it the same size as the hole in the QD. Use a soft steel rod against the ball and give it a good whack with a heavy hammer. It will swage a perfect seat for the ball if you hit it hard enough. The ball should be very hard and undamaged.
I used to work as a machinist at a place that manufactured hydraulic equipment and that's what we did. We used a brass rod, but soft steel should work as well. If you have aluminum use that.
So I didn't find any brand name on these QD's. Just "Made in China" and the size / thread. I did as the rep said yesterday (rinsing them out) and they both still leak ( I figured this would be the out come) . I decided to contact them using there online chat this time around. Explained the problem again and what I'd done per the other rep. They said they'd send me an RMA but wouldn't ship out replacements until after they received the defective ones.....That's pretty handy right there...
They also won't credit my money. Only store credit or exchange of merchandise. So I guess I'll be getting my QD's back in over a week and who knows, maybe these will leak too. LESSON LEARNED!
Went to my local automotive parts store of choice and found out they deal in Gates hydraulic hose and fittings. They had two in stock and the best part was they say Made in the USA! Put them on and they worked perfectly. So I know where I'll be going from now on, and I know where I wont be going :eek:. It's too bad because they do advertise on TBN which pays the bills so we can have these conversations. So does anyone need some import female QD's at a slight discount over retail? :laughing:
/ Made in China quick couplers #17
I sure would like to the name of the place of purchase so, I'll know where not to buy.If they knew they had problems and knew about washing out their QD then, they should clean/wash them out b-4 they sell them. Sometimes it just pays to buy local. If you have problems you just take them back
Spartan RT-HD Zero Turn Mower (A66285)
Spartan RT-HD Zero...
Kubota SVL95-2S (A64126)
Kubota SVL95-2S...
1983 John Deere 2940 Tractor (A62613)
1983 John Deere...
2015 Freightliner M2 106 Terex Hi-Ranger TL55 55ft. Insulated Material Handling Bucket Truck (A60460)
2015 Freightliner...
WACKER NEUSON LIGHT PLANT (A65643)
WACKER NEUSON...
2015 Peterbilt 337 Galbreath CH8000 Container Handler Truck (A64194)
2015 Peterbilt 337...
