Rotary Cutter My new craigslist find
/ My new craigslist find #1
Degolyerent
Gold Member
I was looking at skidsteers on craigslist and ran across a ad that was out of place for a Schulte XH600 rotary cutter that was stated to be in good working condition for $650. I already have a Landpride RCR2672 which I work very hard at times and have worried that if I break it I would have no back up cutter to carry my tractor business forward until parts could be obtained.
The Schulte cutter comes with 160 hp gearbox and it is advertised to cut 4", it also has double safety chains standard which is good cutting in areas where discharge could be a problem. Anyway I contacted the guy and asked a few questions as to condition and decided to go take a look. It was 145 miles away but if it checked out I knew it would be a good buy after doing my research. It has surface rust on rear of cutter but not bad and paint will renew my investment, the 7gauge steel deck had no bad rust. The underside of the cutter was in good shape exception of blades needing to be replaced. The gearbox turned easily and had no signs of leakage, and was full of oil, the driveshaft was in good shape with the guards intact, all metal was in good condition with no bends.
Come to find out it was a state cutter and they had bought 6 at auction and this was the last one, the others he had sold for $950 and was selling the last one cheaper to be done with his investment, I was going to talk the guy down but after looking at it I was happy to give him the full price.
Now I have some cosmetic work to do but ended up with a cutter that hopefully will be more of a workhorse than my original cutter. I will post some pics as I clean up and repaint it.
John
/ My new craigslist find #2
Sounds like a pretty good deal and now you do have a back-up unit.
/ My new craigslist find #3
That is what I hate about Craig's list. I find and buy things that I was not searching for. :)
Sounds like you got a winner and now have a back up plan.
/ My new craigslist find #4
x2. You definitely have to hop on the deals when you find them.
/ My new craigslist find #5
i agree he who hesitates loses.i bought some nice stuff on Craigslist have to jump on it fast.
Thought I would add pic of cutter before I start on it.
/ My new craigslist find #7
I believe that Schulte XH600 is a 72" wide cutter (according to the Schulte specs). That makes it an incredible bargain. It was worth every penny of $950, but you stole it at $650. GREAT BUY!!!
I wire brushed and cleaned the driveshaft connector and hooked it to the pto and everything spun real smooth and quiet, I went to the parts dealer and bought new blades with bolts and nuts and ordered the skid shoes. I also bought a couple different wire wheel attachments for my grinder and some Naval Jelly, I am going to brush the surface rust and treat it then use rustoleum products to treat and prime, then paint top and bottom. I know the bottom paint won't last to long but the spots it stays on will be protected.
I also called the Schulte dealer in Orlando and they have a 2011 unit for $6800 or can get a new one from Canada for $7200 plus tax. I never knew they were so pricey but after researching the unit it is built like a tank and passes OSHA and state standards for highway right of way work.
John
/ My new craigslist find #9
Sounds like you hit the jackpot on this one! Can't wait to see it all cleaned up.
Joe
2015 HINO 195 16FT BOX TRUCK (A59905)
2015 HINO 195 16FT...
Giyi GY-TB47 Telescopic Forklift Boom (A60463)
Giyi GY-TB47...
2025 Pabreak Hydraulic Excavator Arm with Tooth Bucket Skid Steer Attachment (A61567)
2025 Pabreak...
MULTIQUIP LIGHT TOWER (A60736)
MULTIQUIP LIGHT...
2004 GMC Sierra 3500 Pickup Truck (A55973)
2004 GMC Sierra...
2011 John Deere 5085 70HP Utility Tractor (A60352)
2011 John Deere...
