Engine oil For DK series Tractors.......Winter is just around the corner
   / Engine oil For DK series Tractors.......Winter is just around the corner #11
I don't use additives.
If your using a good oil you shouldn't need additives.
May do more harm than good in my opinion
   / Engine oil For DK series Tractors.......Winter is just around the corner #12
Vince, I am thinking about going to the Rotella synthetic T6. Other than the cold weather start advantage, which is not all that important here, What other benefits could I expect over the dino Rotella I have been using.
James K0UA
   / Engine oil For DK series Tractors.......Winter is just around the corner #13
James K0UA
You could go farther on oil changes but you have to test your oil. I use the same oil as you James and I'm sticking to it cause I change my oil every year which is about 100 hours or so.
   / Engine oil For DK series Tractors.......Winter is just around the corner #14
I think cold weather starting is the only real advantage you would see with the T6.
The Dino 15w-40 Rotella is a very good oil.
   / Engine oil For DK series Tractors.......Winter is just around the corner #15
Thanks guys..
James K0UA
   / Engine oil For DK series Tractors.......Winter is just around the corner #16
The important thing is to use a API C-rated oil (C for compression ignition i.e. Diesel) .
ironically C stands for 'commercial'.. not compression.
Likewise S stands for 'service' not spark.
I think they should have uses S for spark.. and C for compression.. but.. API thought differently ;)
   / Engine oil For DK series Tractors.......Winter is just around the corner #17
I use the Mobil 1 in my Merc but I go 7500 to 8000 on a oil change.And I have 96000 on a 09. I change my tractor oil every year and that's about 100 hours or less so why have the expense is my thinking.
   / Engine oil For DK series Tractors.......Winter is just around the corner #18
You are right. I always heard it spark/compression but never actually looked it up.
Thankyou everyone for your responses, I think I will be using the 5-40, T6.
We get some weeks of single digits and many in the low teens.
Cold weather starting is hard on things, I think The oil getting to where it needs to be in a timely fashion is important, and the motor not having to try and pump syrup will certainly make it start easier
and run smoother upon startup.
Not a tractor, but two identical duramax pickups fired up at 18 degrees one with T6 and one with Rotella 15-40, My Rotella T6 cold start experience... - Bob Is The Oil Guy
   / Engine oil For DK series Tractors.......Winter is just around the corner #20
Anyone have any thoughts good or bad about running the 15/40 Chevron Delo in their diesel tractors? I'm a complete noob when it comes to diesel engines and am approaching the 50 hour mark. Thanks.
1991 International 4900 Box Truck (A55315)
1991 International...
2014 UTILITY VS2RA 53FT REEFER TRAILER (A57880)
2014 UTILITY VS2RA...
2021 Ford F-150 XL (A53317)
2021 Ford F-150 XL...
2003 International 9200I (A53317)
2003 International...
2013 PETERBILT 389 (INOPERABLE) (A55745)
2013 PETERBILT 389...
2016 TRAILSTAR 40FT DUMP TRAILER (A56129)
2016 TRAILSTAR...
