Loader Rebuild Cylinder and Valve Question
   / Rebuild Cylinder and Valve Question #1
Doug_Norman
Liberty Hill, Texas
Kubota L3130 HST
I have a Kubota L3130D HST with an LA513 FEL and I need to make two repairs.
1. The left hydraulic cylinder that curls the bucket is leaking (just dripping) and needs to be rebuilt.
2. The FEL hand control valve that raises and lowers the FEL is sticking.
I'm hoping to make the repair myself, so I'm wondering.
1. Where is the best place to order parts?
2. Is there information available on how to make these repairs? I'm mechanically inclined and don't mind fixing things.
I'm also not opposed to bringing it to my dealer, if that is really the best advice. I brought them a cylinder in the past and watched them repair it. It was a bit entertaining - I thought they would have some special tool to install the new seals (o-rings?), but it was pretty much a brute force operation.
Thanks in advance for any help.
   / Rebuild Cylinder and Valve Question #2
I'm no expert on the cylinder...or the valve for that matter but I would check the linkage (joystick) and I would also pull off the lower spool caps and check for rust/gunk etc. on the end of the spool that could be making it stick...
good luck...
   / Rebuild Cylinder and Valve Question #3
I bought the shop manual for my FEL, it has instructions on rebuilding control valve and cylinders. Probably worth the money to pick one up for your loader. As far as parts, I'd order them online from Messick's. I can't remember where I bought my manuals, might have been from Messicks.
Thanks Slash Pine - Yeah, I did all the "easy" checks hoping maybe something just needed some grease. But it appears to be in the valve itself.
I'll give Messicks a try. Thanks.
Any advertisers on this sight out there who can help? I'd be happy to patronize your business.
   / Rebuild Cylinder and Valve Question #6
When my LA853 loader cylinders started leaking (internally) I briefly considered rebuilding them myself, but it usually takes some pretty heavy stuff like bench vises and cylinder nut wrenches that I would have to find or fabricate and I learned on this forum that there is a significant risk of damaging new seals if they are not installed exactly right. So I opted to use the local hydraulic repair shop who do cylinder rebuilds day after day. NOT the dealer! IIRC, each Kubota seal kit ran about $50. They used aftermarket kits for about $35 each after they found that Kubota parts would need to be ordered. The cost to rebuild two cylinders was only $200. They also did a few extras like polishing the old rods, and they bench test them after rebuild. They work perfectly and are also now guaranteed. I figured it was a really good value.
I concur with slashpine on checking the spool caps for gunk regarding the valve sticking issue. They are a known problem area.
Good luck!
- Jay
Local hydraulic repair shop? I'll check around for that.
   / Rebuild Cylinder and Valve Question #8
Doug_Norman,
How did you check the valve for binding?
If it is cable operated, the cable could be binding.
If lever operated, is the lever pivot points lubed?
It might be a good idea to tear the valve down and inspect and clean.
Could be a small bit of rubber or metal hanging up on the spool.
Sometimes the the valve will bind if the mounting bolts for the valve are tighten to much.
If you are going to tear down the valve, do it in a clean place and use a magnet to catch the parts.
Lube everything with hyd fluid and put it all back together.
   / Rebuild Cylinder and Valve Question #9
Hey Doug,
I just resealed all four of the cylinders on my LA680.
The hardest part was removing the nut from the rod, to remove the collar around the rod. I ended up putting the rod end back in a loader pivot point and using a 3/4" breaker bar and a two foot long pipe extension.
A couple of picks and out came the seals, the main wiper on the rod end actually crumbled.
I had to call a friend to double check which direction the ridge on the internal rod seal went, ridge to the outside.
My rods were in good shape, no nicks or scratches.
Give it a shot it was not too bad.
Ken
It is lever operated. By sticking I mean it is no longer smooth to operate. For example if I start in the home position and start to lower the boom I will slowly push up on the lever until it finally jerks a bit and the boom slams downward a bit. It also feels a bit "crunchy" to operate. Interestingly though, the bucket curl (left and right lever motion) feels fine - it is smooth.
   / Rebuild Cylinder and Valve Question #11
Have you removed the spool to check for debris? Bits of rubber, metal, etc.
With everything removed from the spool, lube it and slide it in the valve housing and see if it is binding, or hanging on anything. If you mark the way it is now, you can rotate it 180 degrees and reconnect everything and check for smooth action.
   / Rebuild Cylinder and Valve Question #12
When I rebuilt my cylinder- I just took it off and took it apart. I cleaned everything so its not oily to transport and took it to my local hydraulic shop and they matched up the seals by taking measurements on the spot and gave me everything I needed.
I'd follow JJ advice for the spool issues. he gives out good advice.
I have not removed the spool. Excuse my ignorance, but which part is actually the spool?
   / Rebuild Cylinder and Valve Question #14
In our neighborhood, it's "Air and Hydraulic Equipment" Air and Hydraulic Equipment, Inc. An Employee owned Company
I used them after talking to one of our old-timer equipment operators at a grading company who recommended them.
I'm sure there is a similar outfit somewhere near you in TX.
- Jay
   / Rebuild Cylinder and Valve Question #15
Thanks all for the help. Great advice. After further inspection, it was rusty crud in the spool cap that was binding the joystick. And as y'all advised the magnet was a good idea as I learned there are 5 ball bearings that want to roll out. I got it all back together and it operates smoothly now!
Today I pick up the bucket cylinder rebuild kit from my dealer. It's a minor leak/drip, but that will be my next repair.
2004 TAKEUCHI TL140 SKID STEER (A60429)
2004 TAKEUCHI...
Forestry Truck Grapple and Frame (A55851)
Forestry Truck...
2018 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59904)
2018 INTERNATIONAL...
John Deere 1025R (A53317)
John Deere 1025R...
UNUSED FUTURE 350 HYD BREAKER HAMMER (A52706)
UNUSED FUTURE 350...
2012 FORD F450 XL SUPER DUTY TRUCK (A59823)
2012 FORD F450 XL...
