Toe In for Kioti Front Axle Dk45/DS45
   / Toe In for Kioti Front Axle Dk45/DS45 #1
dennis52
Gold Member
Queensland Australia
Kioti DS4510HS , Kubota B7100
The Service Manual for my 2011 DS4510 (same front axle as current DK45s ) states that, following adjustment of the tie rod ends in order to obtain correct toe in , that I should retighten the tie rod lock nuts to 270-316 lb/ft.
Now this seems to me to be a very high torque rating for a lock nut that size. Advice would be appreciated
If the toque spec is correct , than I am not sure how to go about trying to measure it.
It seems the only tool that would be suitable for the job would be a flare nut wrench with a long lever on the end (and guess the torque)
I have two torque wrenches but they only go up to 150 lb/ft however even with a higher rated torque wrench you would not be able to fit a socket onto the nut anyway.
I am leaning towards ignoring the torque spec completely and tightening the lock nuts to about 50-70 lb/ft with a 12'' long flare nut wrench
Any thoughts
   / Toe In for Kioti Front Axle Dk45/DS45 #2
Wow that seems excessive, must be a misprint. Maybe it is newton? But that would be 233 to 199 ft# still. On all the ones I have done in the past, cars, trucks they were 45 to 65 ft#.
Here is a copy of the spec in the manual
Lock nut........................367.5 ~ 431.2 Nm
37.5 ~ 44 kgf-m
270 ~ 316.8 lb-ft
   / Toe In for Kioti Front Axle Dk45/DS45 #4
It's gotta be a misprint. I just put two wrenches on the flats and give it one good grunt. There are more than a few errors in the service manual for my 451 but neither my owner's manual or service manual specify a torque specifically for this lock nut. There is some generic torque data (based on size) at the beginning of the maintenance section.
   / Toe In for Kioti Front Axle Dk45/DS45 #5
More: The maintenance sections in the DK451/45S OM and SM don't specify the torque. But back is section 7 (front axle) of the SM there is a spec of 123.0 ~ 144.6 ft lb for the tie rod locking nut. This still seems high to me by a factor of two. As long as it doesn't work lose, it is tight enough IMO.
Thanks guys for steering me in the right direction (pun ). Common sense the way to go.
   / Toe In for Kioti Front Axle Dk45/DS45 #7
might be inch pounds!
2005 Jeep Wrangler 4X4 SUV (A56859)
2005 Jeep Wrangler...
Honda Pioneer SXS700 4X4 Utility Cart (A55758)
Honda Pioneer...
LIMA MAC 30KW GENERATOR (A58214)
LIMA MAC 30KW...
2015 AMERITRAIL MANIFOLD TRAILER (A58214)
2015 AMERITRAIL...
6" CONVEYOR BELT (A54757)
6" CONVEYOR BELT...
2017 Mercedes Benz GLA SUV (A56859)
2017 Mercedes Benz...
