Pulled The Trigger - New L3200 HST with FEL and Brush Cutter
   / Pulled The Trigger - New L3200 HST with FEL and Brush Cutter #1
mopac01
Member
Kansas City
Kubota L3200HST
:cool2:
I've pulled the trigger on a brand new Kubota L3200 HST with the FEL and a Landpride RFC2060 brush cutter with the flat top and optional chains for guarding against kickouts. I wanted to get one while I could still find one. They've stopped manufacturing them as they switch to tier 4 emissions. I didn't want to be part of that switchover and price increase. I had all 3 rear remotes added and the 3pt stabilizer. I had the rear tires filled with Rim Guard so I'll have another 1,200 lbs of weight. I bought an 18' trailer to haul it with double axle (3,500lbs each). I need to take the old F-150 up to get the electric brake controller added since my current boat trailer has surge brakes. I'm so happy to be saying farewell to my current Ford 2N and brush cutter. I never knew if I'd get to spend time using it or trying to get it to run.
I still need to decide on a tiller. It's down to the Landpride reverse tiller RTR1550 or RTR1558. The 3200's manual lists tiller width at 54" max but the dealer said he puts 66" tillers on these Ls to cover both tires. Since I only need to maintain a small horse arena and a 25'x25' garden I think the 50" would be sufficient if I offset it to cover 1 tire. I don't really see the advantage of the 66" except in time - which would be minimal in my application to begin with.
   / Pulled The Trigger - New L3200 HST with FEL and Brush Cutter #2
Congratulations! That sounds like a nice set of equipment.
   / Pulled The Trigger - New L3200 HST with FEL and Brush Cutter #3
enjoy your new tractor.
   / Pulled The Trigger - New L3200 HST with FEL and Brush Cutter #4
Consider a King Kutter 60" unit. Nice unit for less $$
Thanks for the suggestion. However I'm absolutely sold on Landpride. They are somewhat local to me and I'm very impressed with the company's story and how the business is run. I want to support those sorts of folks.
   / Pulled The Trigger - New L3200 HST with FEL and Brush Cutter #6
How much did you pay for all that setup ?
   / Pulled The Trigger - New L3200 HST with FEL and Brush Cutter #7
Pictures? Sounds nice.
2010 NEW HOLLAND B95 BACKHOE (A50854)
2010 NEW HOLLAND...
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50322)
BW RVB3405...
2022 Ford F-550 XL Crew Cab Forestry Chipper Truck (A49461)
2022 Ford F-550 XL...
FUEL TANK/TOOL BOX COMBO (A50854)
FUEL TANK/TOOL BOX...
2013 MACK ELITE LEU633 GARBAGE TRUCK (A51243)
2013 MACK ELITE...
2013 Honda CR-Z (A50324)
2013 Honda CR-Z...
