vista laptop - security center empty, firewall not on, can't update, add/remove prog
   / vista laptop - security center empty, firewall not on, can't update, add/remove prog #61
About a dozen different programs that do just that..
And, as said, you still have a 'desktop' like any other windows. Just no 'start button'. I never used mined anyways.
   / vista laptop - security center empty, firewall not on, can't update, add/remove prog #62
Well, that would be a no-go for me. I use the start menu and the search box in Windows 7 very regularly.
Aaron Z
Aaron Z
same here...
   / vista laptop - security center empty, firewall not on, can't update, add/remove prog #64
As this thread has wandered a bit I'll help it wander more. :)
I'm not a big fan of Wndows 8 especially having to log on as I am the only one here. To get around that try:
"On the desktop screen (not metro), right click on the bottom left corner and you will get a menu. Select Command Prompt Administrator mode.
On the command prompt, type "control userpasswords2" without the quotes. You will get a menu where you can untick "Users must use a password to use this computer". Press OK, and it will ask you for the username and password to use by default. Once you enter the details and reboot, it will no longer ask you to login."
It will still ask for a login if your laptop hibernates and you want to reactivate.
I will wait for 8.1 (which I think is end of Sept) and see it I need to look at Classic Shell
I also wonder about all this 'get a new OS because XP will no longer be supported' rubbish. Xp's been out for so many years now, how much support does it need ?? It's still going to work so why spend the money ?
2021 Ford F-250 (A55973)
2021 Ford F-250...
2020 Husqvarna YTH22V46 46in Riding Mower (A56859)
2020 Husqvarna...
2014 International Bucket (A55973)
2014 International...
84" HYD ROCK GRAPPLE (A52706)
84" HYD ROCK...
2020 DRAGON ESP...
IRTPL 10,000 LBS TWO POST LIFT (A58214)
IRTPL 10,000 LBS...
