5093e Update
   / 5093e Update #11
1300lb round bales are light.wonder how it would lift a 5 by 6 1800 to 2000lb bale.i talked to a lady that says her 5525 jd grunts lifting a 1300lb bale on the loader.
The H260 loader will lift over 3,000 pounds so 5x6's would not be a problem. I was using the 1,300 figure at an idle as an example of how easy it'll move anything you wanted it to move.
   / 5093e Update #12
H260 loader with 5 series carrier
Frontier AB13E Heavy Duty Spear
Frontier HS2001 rear hay spear
JD MX8 pull type mower
Deluxe Air ride seat
Dual Mid
Dual Rear
Right hand door
dual rear weights per side
Dual Aux light front and rear
Power Strip
POwer Shuttle Control
Rear Wiper
Sway bar conversion
Instructional seat
LH and RH Mirror
Front Weight Bracket
Radio
Did I miss anything?
D.
Grill guard, unless included with the loader
   / 5093e Update #14
Tool box?
   / 5093e Update #15
Tool box?
Comes with one mounted in a stupid place that makes it impossible to add fuel with anything other than a true nozzle from a pump. I took mine off after dumping most of a 6 gallon can on the ground trying to get diesel in the tank. The 93 is a great tractor but no designer ever tried to put fuel in one. If they had the tool box would be somewhere else. It's bad.
   / 5093e Update #16
There is just no good way to put a toolbox on these. I have a 5520 open station and the choices are even worse than yours.
   / 5093e Update
I have a 5525 with a 542 SL loader. It is a good loader. 2000lbs is not a problem. The 5525 could be configured with a number of different loaders - so it is hard to say. I cleared 100s of cedars with mine and have really used the heck out of the loader. I would not call it weak. It will not pick up a complete pallet of concrete, but oh well.
D.
   / 5093e Update
Comes with grill guard and toolbox.
D.
   / 5093e Update #19
I have the H260 loader on my 5M and I like it. I just have the standard hook and pin attachment but it works fine for me. The bucket or hay spike come off and on without a problem.
I took my toolbox off too. Got a tool bag from Sears and keep it in the cab next to the seat.
   / 5093e Update
The standard hook and pin is the 5 series setup. I already have stuff for a 5 series or I would go skid steer.
D.
2019 ALLMAND NIGHT-LIFE V SERIES LIGHT PLANT (A52706)
2019 ALLMAND...
2017 Ford F-150 Pickup Truck (A55788)
2017 Ford F-150...
2012 BMW 328i Sedan (A53424)
2012 BMW 328i...
2016 INTERNATIONAL 4300 24FT BOX TRUCK (A54313)
2016 INTERNATIONAL...
2021 Dodge Durango GT AWD SUV (A55758)
2021 Dodge Durango...
UNUSED LANDHONOR LHR-WS22 WEBBING SLINGS (A54757)
UNUSED LANDHONOR...
