Did you think the damage wasn't too bad? And then.....
   / Did you think the damage wasn't too bad? And then..... #11
Looking at the pictures not sure if I'm looking at a sports car or tractor. :D
It's aerodynamic. It helps me attain my 12mph top speed!:)
   / Did you think the damage wasn't too bad? And then..... #13
Ouch... I just broke the little tab on my hood of my BX. Stupid me was trying to force it back on and realized I didn't have the knob loose enough until... CRACK! :hissyfit:
This will definitely be a super glue job though and I can't imagine what an entire hood would cost if the light is $300!
   / Did you think the damage wasn't too bad? And then..... #14
I would make a metal version of the broken piece that goes back to the side of the hood and pop rivet it on or make a plastic overlay for the whole section and epoxy it on. Glue wont hold in that break.
Alternatively, get a fender washer (or two), put it under the knob and use that to "grab" the un-broken part of the bracket (either one on top, or two to sandwich it).
Aaron Z
   / Did you think the damage wasn't too bad? And then..... #15
View attachment 333477 View attachment 333478
That sucks! I don't know if super glue is going to be a good repair for that - especially with all the vibrations. I would make a backer-plate out of aluminum and pop rivet it to the broken piece(s). Of course, that's just my opinion!
   / Did you think the damage wasn't too bad? And then..... #16
I would make a metal version of the broken piece[...] Aaron Z
Oops! Looks like you responded before I finished typing. I do agree with your response also. Either way, I think he's better off with a patch plate than the SG.
   / Did you think the damage wasn't too bad? And then..... #17
I surely don't mean to hijack this thread... I was only trying to empathize with the OP. I realize the SG isn't the permanent answer but the tab is just in compression so I just need it to support the knob when it is tightened down. I am actually in the adhesives business so I appreciate its abilities. Oh well.
   / Did you think the damage wasn't too bad? And then..... #18
There once was a time when car headlights were large, round, fit on any car and cost maybe $10. Then we got little round ones, price up to $15 each and you needed 4 instead of 2, followed by rectangular types, both large and small and prices at $20 per. Now you have to get a swoopy shaped built-in lens assembly that costs a house payment, with a replacement bulb that's $30-50. I think I see a trend here... somone's making money on this stuff and wants to perfect the technique.
   / Did you think the damage wasn't too bad? And then..... #19
Your a wise man Grandad4.
   / Did you think the damage wasn't too bad? And then..... #20
I assume the headlight still works. If so, I also would leave it alone. But, thinking about this, I realize I probably have never used my headlights. In summer, it stays light enough all day to get done what I need to get done. In winter, I don't use the tractor to snow plow so, don't need it when dark. Anyway, good luck.
MoKelly
1999 FREIGHTLINER FL80 SWABBING UNIT TRUCK (A58214)
1999 FREIGHTLINER...
Deere 35G (A53317)
Deere 35G (A53317)
2018 Toro Reel Master 5510-D Fairway Reel Commercial Mower (A56857)
2018 Toro Reel...
HIGH END MINI GOLF CART (A58214)
HIGH END MINI GOLF...
12' CONTAINER (A52706)
New Wolverine 84in 5way Skid Steer Scrap Blade (A59000)
New Wolverine 84in...
