Gonna build a bandsaw mill.
   / Gonna build a bandsaw mill. #1
Pa Pa Jack
Hodges, SC
Mahindra 3016
I am going to build a bandsaw sawmill to make lumber out of the trees I clear on my property. It is an idea I've had for a long time. I do some woodworking and hate to burn some of the wood I cut yearly. My problem is kinda silly. I have ordered or have most of the materials I need. I do have to buy an engine to run the danged thing. I want a 13hp engine. I went to order one from Harbor Freight and they have engines that rotate clockwise and counter clockwise. I guess I just never thought about that. Which is normal? How do you say if it's clockwise? Is that determined looking at it from the front or the rear. It's not nice to confuse an old man. :laughing:
   / Gonna build a bandsaw mill. #2
I believe standard is counter clockwise. That's determined by looking at output shaft.
I never realized that. I just found a thread on another site where they were discussing that. I ordered the counter clockwise motor. And got 25% off with a coupon. Saved almost $100.
   / Gonna build a bandsaw mill. #4
I have a Baker HD18. It has a 20hp Honda. 30" diameter log capacity.
   / Gonna build a bandsaw mill. #5
Please post back during your build with plenty of pictures.
   / Gonna build a bandsaw mill. #7
I would think it all depends on which way the blade you use is suppose to run. Blades only run one way. I don't remember if they can be turned inside out. I can check on that Monday night at work.
hugs, Brandi
hugs, Brandi
Yeah, my wife suggested I just turn the saw over. :)
   / Gonna build a bandsaw mill. #9
You can invert a small band quite easily. In fact, you have to if you have a tooth setter that only operates from one side ( which is what Woodmizer sold when I bought my sharpening package )
   / Gonna build a bandsaw mill. #10
The direction shouldn't matter. You will have a clutch on the o/p shaft connected by v belt to one of the band wheels. The blades can be flipped inside out if it is set backwards for your mill. Looking forward to watching your build. Take and post lots of pictures. :thumbsup:
2 Vintage Metal Signs (A48081)
2 Vintage Metal...
2019 CATERPILLAR D6 LGP CRAWLER DOZER (A51242)
2019 CATERPILLAR...
2-Row Peanut Inverter (Chain Drive, PTO, 3-Point Hitch) (A51039)
2-Row Peanut...
2018 Toyota RAV4 SUV (A50324)
2018 Toyota RAV4...
2017 Ford F550 4x4 Bucket Truck - 45FT Terex TL40 Boom, Powerstroke Diesel, Utility Bed, 54K Miles (A51039)
2017 Ford F550 4x4...
2018 CATERPILLAR 308E2 CR EXCAVATOR (A50458)
2018 CATERPILLAR...
