TFR
Been searching around this forum for months trying to search out information that would help make decisions, but I have not been able to find the answers to some of my questions. I thought it was time to join the forum and ask directly. I would appreciate any help, suggestions, or comments that anyone has regarding some of my unanswered questions or other things I should be considering regarding my potential purchase of a new 5115M with a deluxe cab and a MSL loader.
I have around 100 acres of very diversified terrain. Everything from level areas of 5 to 15 acre clear pastures to steep scrub covered hills, to areas of dense mature tree cover, and areas of moderate to steep hillsides with slide areas and slip-outs that are in need of repair, year around wet areas, and several miles of dirt roads and pathways to make and maintain. I'm located inland from the coast so it can be very hot in the summer with 100 degree plus days, and very cold and wet in the winter (when there is no drought).
Some questions/concerns I have are:
1. Does the weight and position of the cab on the tractor (height wise) change the center of gravity in a substantial way. I now mow cross ways on some fairly steep hillsides with my Kubota, but it is a lot smaller and closer to the ground. Is the 5115M stable on cross slopes. Is the 5115M with a cab going to be more prone to getting into trouble on cross slopes than an open station 5115M?
2. I'm debating on going with the standard R1 tires or the "construction like tires" that have a little wider tread stance which may add to the overall stability of the tractor on hillsides. I plan on having the rims mounted for the maximum width. Which tires provide the lower center of gravity? I could not determine form Deere's specifications. Anyone have any comments or opinions on this? Wheel weights or water or both?
3. The dealer could not provide me the capacity in cubic yards of the standard loader bucket. I'm used to seeing things like 1.25 cu. yds. heaped or something like that. Does anyone know?
4. Any comments regarding the must have features versus the things to avoid would be welcomed. I hope to hay portions in the future. I'll be purchasing/using a 10' or 12' drag scrapper (with hydraulic rippers, if there is such a thing), fork lift loader attachment, maybe the grapple option with just the standard loader bucket.
5. Does the training seat take up valuable space in the cab and make it cramped for the operator? I would like to have a safe way of teaching the young grandson the ropes.
6. This would be my first Deere. Is it a reliable machine? Does the air conditioning freeze you out of the cab if left on max cooling or does it barely keep up with the heat on very hot days and heavy tractor work? Does the air conditioning system continue working well for 6 - 10 - 12 years without problems like freon loss, compressor problems, etc.? I'm to the point where I want some level of comfort from all the extreme elements and the dust and pollen. Good air conditioning and heating and must as well as dust/pollen filtering in the cab.
The dealer is arranging a checkout inspection and test operating session with a 8 month old M series tractor with a cab at one of his customer locations this week. If that goes well then I would like to try an arrange to get a M series tractor with a cab to my property so I can really see first hand how it performs doing real work and how it feels on the steeper slopes before I actually purchase one. The dealer does not have any M series in a rental program or a rent to purchase program. I'm not sure if I want to purchase one if I can not try it out first on our property. This may be a deal breaker.
Curiosity question: I've read a lot of posts and responses from AK in Alaska. I like his tractors and his state but my question is what do you grow in that very short growing season?
Take care and stay safe,
TFR
TFR
