What is "splitting tractor"
/ What is "splitting tractor" #1
spivey44
Atlanta, Ga
Kioti CK27
I have seen a couple of references to splitting the tractor to repair items such as sticking FWD/RVS pedal and clutch.
What exactly does this term mean ??
I'd think one would simply do the needed repair so what exactly are we splitting?
/ What is "splitting tractor" #2
It means splitting the cases( engine, trans, rear end) to access otherwise inaccessible areas for repair.
Sent from my LGL35G using TractorByNet
Thank you. Sounds like a not inexpensive endevour.
/ What is "splitting tractor" #4
Not if you have a shop do it...It's a pain to do yourself, but as long as you block everything well to keep it from rolling/falling on the floor, it can be done.
/ What is "splitting tractor" #5
Splitting involves separating the tractor into two big pieces. I've never done it myself, but I suspect that all of the hydraulic lines, control linkages and electrical connections between the 2 halves need to separated, too. On a newer, complex tractor this looks like a major part of the work. That and fixturing both halves, as adirndack describes, so that nothing drops or tips over, but so that one half can be rolled away from the other, then back together to reassemble eveything once the repairs have been done.
/ What is "splitting tractor" #6
Difficulty depends on the tractor. A tractor is basically 3 major parts. A rear axle, transmission, and engine. To take any one of those items separate from the other is "splitting" the tractor.
Modern tractors with lots of electrical, and tractors with loaders or backhoes can be very difficult.
Older tractors that the engine-transmission-rear end were all heavy cast iron and had no other frame work, those were easy. Like an old ford 8n. You could split one of those in an hour or two to change a clutch.
/ What is "splitting tractor" #7
Sometimes trains do it.
Pictures 2003
/ What is "splitting tractor" #8
It's not as glamorous as one may think. It's usually done with floor jacks and jack stands, not the fancy fixtures they show in the manuals. I've split more than I can count, many of those in the dirt using a piece of 1 1/8" plywood for the jack to roll on.
Brian
/ What is "splitting tractor" #9
Brian
Been there done that got the Tshirt. It was in January and around-25C
/ What is "splitting tractor" #11
The splits are at the engine/transmission interface and at the transmission/rear end interface on most modern tractors.
Here's an example--my 1951 Minneapolis Moline BF tractor being reassembled after a complete restoration. The engine has been removed and is on a run stand. The split occurred between the rear of the engine/clutch assembly and the driveshaft on this old tractor.
Hope this helps.
ELECTRIC POWER WASHER (A64278)
ELECTRIC POWER...
2013 Honda 250 Recon ES ATV (A64557)
2013 Honda 250...
2017 Hyundai Santa Fe AWD SUV (A61574)
2017 Hyundai Santa...
Winchester Sign (A64557)
Winchester Sign...
New/Unused 72in No Till Seed Drill (A65583)
New/Unused 72in No...
JOHN DEERE Z515E ZTRACK ZERO TURN MOWER (A65054)
JOHN DEERE Z515E...
