MtnViewRanch
Elite Member, Advertiser
- Joined
- Mar 19, 2005
- Messages
- 10,641
- Tractor
- Mahindra 7520, Mahindra 3215HST, Case 580 extendahoe, Case 310 dozer, Parsons trencher, Cat D6,
Those braces wouldn't be needed for the lower end of the rated HP range. This particular box is going to be rated for up to a 180hp 4wd tractor or 220hp 2wd tractor so the support will be needed.
With a depth of 44", the braces shouldn't limit the performance whatsoever.
Come on man!! You want heavy, and now you want it lighter??
I know exactly what you're saying. Ted wanted to start with the Beast, which will be the heaviest model and then work his way back down to models that are more in line with the Gannon.
The market for the Beast is probably even less, but there is a market. It is aimed more for land clearing and grading behind very large tractors.
After this blade, he will make some "superboxes"(I like that name) that are more in line with the gannon with options like retractable shanks and hinged backs.
The Viper cutting edge by Valk will be the largest, heaviest cutting edge being used on any 3pt attachment according to the manufacturer.
He's probably going to offer this Box in 78,90,96,108 and 120" widths and the cost will depend on just how much labor is involved.
A couple of things, and I could be waaaaaay off, what do I know? :confused3:
I mentioned cutting weight to lower the obvious HUGE cost.
No one had mentioned building a unit for 100+ hp machines. Yes maybe it will need to be this massive for BIG tractors. Do you really think that any 100+ hp tractors will want anything less than 96"? Why would anything as small as 78" in width be used behind such a large machine?
Do you actually see any call at all for a 3pt hitch box blade for a 180hp tractor? I would think that if there was a need, there would be some already available. I suppose if you create a product, someone will buy it. :confused3:
Again, I don't know, have no idea, way out of the scope of anything that I have ever dealt with.
