Front Bucket Cam, Gauges and Central Vacuum system installed on my Grand L 3240
/ Front Bucket Cam, Gauges and Central Vacuum system installed on my Grand L 3240 #1
WaxMan
USA CT
Kubota Grand L 3240 cab BH 92 backhoe
This isn't for everyone, but this is what I did.
First I wanted to have the least obstructive gauge set I could find with the smallest footprint. For what I had in mind and the limited space I had to mount them. I could not find anything anywhere that I liked and that was small enough for the space. I had no choice but to make my own.
I had to get the backup monitor mounted and up out of the way, I used the adjustable mount that came with the monitor. I removed the cheap stick-on double sided tape base and machined an aluminum mounting adaptor to mount it securely to the dash. I bought an Agcam camera and monitor, it's a lot more expensive but you see where the camera is mounted you'll understand why. I wanted a strong camera to hold up.
Once the monitor was installed I was able to see what space I had left to work with, for the gauges.
I searched for a long time for gauges before deciding on theses MaxTow diesel gauges. I like the analog and digital in the same gauge kinda like my Kubota dash analog and digital.
For the gauge pods I used 2 inch copper pipe scrap that I had laying around, I cut it into four sections, I had to bore the insides larger on my lathe to make a 2 1/16 '' gauge fit into the copper pipe, then I had to figure out how to bolt down the gauges in the 4 pipe sections (and) mount the four pipe sections as one unit (and) hide all the wires. I had some ideas but all involved soldering a lot off little washers to the copper gauge pods. I don't plan things out like an engineer I end up making stuff as I go as problems arise, I'm always changing things it seems from the original plan in my head.
After some thought, I milled a 3/4 inch copper pipe in half on the Bridgeport, (another thing I had on hand) then milled out each copper gauge pod to fit the half round 3/4 pipe then silver soldered it all together.
With that 3/4 copper pipe idea I now had a way to mount the gauges in the copper pods, I had a place to run the wires toward the middle without showing and I was able to mount the whole gauge assembly to the 1/8 thick copper flat stock base with three small hex screws.
I sandblasted the whole setup first, then I use high heat auto engine paint, with that paint still wet I heat it in an old toaster oven at 300 degrees for about thirty minutes , the paint shrinks into the sandblasted nooks and crannies, by doing this the finish is bonded to the sandblasted metal, baked on, to a hard, thin, scratch and chip resistant finish, dry and ready for use. On larger pieces I use my heat gun. I learned this trick years ago by accident from being impatient waiting for paint to dry. Makes the finish like a factory job. I just wish I dusted the gauges off before taking the pictures.
I purchased the Agcam monitor and one camera. The monitor can handle up to four cameras on the screen at once, Before hooking up the backup camera I thought I would experiment with a camera up front. If it didn't worked well I would just put the camera in the rear for a backup camera, If it did I would buy another one for the back.
I made the front camera mount it in two pieces, one piece is bolted to the quick hitch using the two quick hitch bolts, the other end is easily removed with a twist by hand unhooking the cable and slide the camera rod out of the base when using the FEL for heavy duty Fel work, working in brush etc, even though the camera is indestructible.
By mounting it to the quick hitch I can change between the bucket and forks without any problems with the camera stick installed.
You can see in the pictures what the operator sees looking out the window and what the camera sees in the monitor. I thought I would use it around the yard and see if its useful or just a pain with that rod sticking out. So far I like it, especially in and near my wife's flower garden where feel and guess work cause problems. It is just amazing how gentle you can be once you see what the blade is doing.
I don't know about you guys but I can't see my forks going into the pallets before I pick them up. Before it was a guessing game, ever pick up a pallet and the forks go underneath instead of getting between the slats? It's very hard to get the pallet off the forks if you pick up the pallet from the bottom. Not anymore look how great you can see what your doing with a front bucket cam. The Agcam sure does cost a lot more but I think it's worth it, even in direct sunlight the monitor looks great, Just a note these pictures were taken on a very cloudy day.
Every time I get in the cab I drag dirt it, No big deal, but after a while it builds up on the floor then it just blows around inside the cab with the air conditioner. So every now and then I drag out the shop vac and clean it up. Not any more, now whenever I need to clean up the floor I just flip a switch and clean it up.
I installed a central vacuum system.
The Vacuum is a Metro 12 volt car vacuum, it's small in size and is all metal. 61.00 on Amazon 25.00 used on ebay. First I removed the switch, handle and feet to the vacuum. Then I sealed the holes rewired it direct because the switch will now be in the cab
Just so happens there was a rubber plug in the cab just about the right size for the vacuum hose.
The complete vacuum was installed without drilling any mounting holes.
Only one 7/16 bolt holds the whole unit on. If I ever want to take it off just remove that one bolt and put the rubber plug back in, back to factory Kubota.
It's not super powerful but it gets all the dirt and dust off the floor because its a mat and not a carpet it works very well.
You say just get a brush and brush the dirt out? but the mat has indents around the pedals and the only way to get it out is to vacuum. Still have to hook up a switch and a rubber elbow on the outlet to stop water from entering.
/ Front Bucket Cam, Gauges and Central Vacuum system installed on my Grand L 3240 #5
Ok so I am reading along, and thinking, yeah that pod construction is pretty cool.. and yep that paint job is first rate, Owww. look at that camera, now that is cool.. but he is still lying about that central vacuum... ha ha good joke....and now the third post.. what the he!!. he actually put in a "central vacuum. Man way cool..I am impressed.
James K0UA
/ Front Bucket Cam, Gauges and Central Vacuum system installed on my Grand L 3240 #6
Nice work, Waxman! Especially like the cool gauge setup.
/ Front Bucket Cam, Gauges and Central Vacuum system installed on my Grand L 3240 #7
Very nice!
/ Front Bucket Cam, Gauges and Central Vacuum system installed on my Grand L 3240 #8
Very cool mods! Since I don't have a cab I'll skip the vac but I love the gauge mount, you did a very good job. Any reason you didn't install an exhaust temperature gauge?
/ Front Bucket Cam, Gauges and Central Vacuum system installed on my Grand L 3240 #9
What are you measuring on the gauges?
/ Front Bucket Cam, Gauges and Central Vacuum system installed on my Grand L 3240 #10
James K0UA
My thoughts exactly!
And if I'm looking correctly, no filter on the vac to have to clean either, just blow the dust back out side. Brilliant!
/ Front Bucket Cam, Gauges and Central Vacuum system installed on my Grand L 3240 #11
You will have to describe your tractor as a "Most Grand" L3240.
Your creativity is way beyond mine.
Let me humbly grovel in your (vacuumed) dust...........
/ Front Bucket Cam, Gauges and Central Vacuum system installed on my Grand L 3240 #12
I wonder if 4shorts is reading this.......
James K0UA
Thanks James, you summed that up pretty good:thumbsup: Tonight I'll post the remote control I'm working on, it's to control the tractor from my living room and watch what I'm doing on the TV,
Now I'm lying:D
npalen
Re: Front Bucket Cam, Gauges and Central Vacuum system installed on my Grand L 3240
Thanks napalen
wmonroe
Thank you wmonroe, I guess trans temp seemed more important.
murphy1244
If I understand the question I guess I'm measuring temp, pressure and volts, after a while I will be able to tell whats normal and whats not. I know every time I start the tractor cold the oil pressure is 55 and when I rev it up it's 69, Volts idling ?? revved up ?? etc. Not enough time yet to remember all the numbers. But you will know if somethings off after time.
jeff9366
Thanks Jeff, but 4shorts has the most Grand
Thank you PumkinPete and CDN farm boy
/ Front Bucket Cam, Gauges and Central Vacuum system installed on my Grand L 3240 #14
Beautiful job, nice work !!!
/ Front Bucket Cam, Gauges and Central Vacuum system installed on my Grand L 3240 #15
Outstanding!
I really like those gauges.
The Agcam is really nice, too.
First class craftsmanship - everything looks well thought out and executed.
That's the sign of real understanding of what you have, what you want and how it will get used.
Hats off to you, sir.
/ Front Bucket Cam, Gauges and Central Vacuum system installed on my Grand L 3240 #16
It will be interesting to see what temp the tranny runs at.
No it won't, not yet anyway, because I really didn't want to use a filter adaptor yet, maybe I'll do it when I do my 50hr. I just put the sender in a threaded 12 mm dead hole on the side of the transmission I made a bushing to fit the 12 mm to 1/8 pipe thread.
Same with the oil temp there was a threaded 10mm x1.5 dead hole about 1 inch deep on the bottom of the oil pan I ran a die over the sending unit and placed it in that hole. Since it was a dead hole I didn't have to worry about any leaks.
The thin aluminum oil pan will probably give somewhat of a accurate reading once hot. But the large cast iron transmission will not accurately tell the temp of the oil IMO. It would have been easier to do the exhaust temp now after thinking about it. I would much prefer the sensors in the oils. Has anyone ever used one of these? I was thinking getting one for the oil filter and transmission filter but I don't know the thread sizes , I figured I would worry about it at 50hrs. I was also thinking of using an coupler and taping into a fitting with a 1/8 pipe tap.
Outstanding!
Thank you Baby Grand that was nice of you to say.
/ Front Bucket Cam, Gauges and Central Vacuum system installed on my Grand L 3240 #19
I don't want to appear negative and I love the camera but I doubt it would work in my environment. I tend to push in a lot of brush and lots of time, just stack it on the lift arms behind the FEL. As you said it can quickly be removed. Gauges are very nicely done also but of all the tractors I have used, I have never had any info other than oil pressure, water temp, fuel and tach and they all seemed to work as they should and last thousands of hours.
Customization is all about what the guy doing the work wants and you certainly did a nice job. Congratulations
/ Front Bucket Cam, Gauges and Central Vacuum system installed on my Grand L 3240 #20
Now THOSE are the absolute coolest things I have seen on a tractor in...like...forever! Great job!
2012 International WorkStar 7400 Service Truck with Crane, VIN # 1HTWGAAR1CJ453408 (A61165)
2012 International...
1973 White Trucks Western Star Dump Truck (A61165)
1973 White Trucks...
2019 KUBOTA SVL95-2S SKID STEER (A62129)
2019 KUBOTA...
2006 Mercades GL Sedan (A60352)
2006 Mercades GL...
24in pin on tooth excavator bucket (A61307)
24in pin on tooth...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
