blown fuse
/ blown fuse #1
Boobelah
Gainesville Ga
Gravely Promaster 350
New member here. I just put a new battery and plugs in my Promaster 350 with the Kawasaki 22 hp gas. It was running before (tho poorly) but now the 25 amp fuse blows every time I turn the key. Any ideas?
/ blown fuse #2
Battery cables are on the correct terminals ?
Can you turn the engine over by hand ? ie. make sure it not mechanically seized.
Rgds, D.
/ blown fuse #3
You have a direct short in the ignition system.
/ blown fuse
Hey guys, thanks for the advice. Yes I did check the terminals first of all as I have done more stupid things in the past. I did check n response to another member's advice that the fuse holder may be bad and not be holding the fuse tightly, thereby causing it to heat up. Bingo! A new fuse holder and its a go! Now to pray the Seafoam does its magic. bob
/ blown fuse #5
I love Seafoam that stuff is liquid Majic
/ blown fuse #6
Well played Bob.
If it is a glass inline fuse, make sure you are using a DC rated fuse (typ. 32v), not 120VAC or higher.
Rgds, D.
378908 (A61166)
378908 (A61166)
2013 Ford F550 Bucket Truck w/ Jib (A62613)
2013 Ford F550...
Lincoln Arc Welder (A62613)
Lincoln Arc Welder...
(3) Steel Wheels (A65640)
(3) Steel Wheels...
2018 TAKEUCHI TL8 SKID STEER (A65053)
2018 TAKEUCHI TL8...
2019 Chevrolet Tahoe SUV (A64557)
2019 Chevrolet...
