NH 565 square baler
/ NH 565 square baler #1
jdegner
Orangeburg, SC
New Holland 565
Hi, this is my first year cutting hay. I bought a used NH 565 square baler. It works great, but I don't know how to remove the last 2 bales produced. I tried releasing the knotter arm and taking all the tension off the tension springs, but those last 2 bales are stuck right in there. Is there an eject? Thanks.
/ NH 565 square baler #3
When I need to remove bales from bale chamber I use a crowbar to get them out.
/ NH 565 square baler #4
Hay hook with a 10' loop of heavy rope hooked to the handle also works well (especially with the belt kicker on our NH 273). Snag the strings though, not just the end of the bale.
Aaron Z
/ NH 565 square baler #5
Put wood blocks in between the bales and the plunger and turn the flywheel by HAND to push them out. If you don't have a number of "6 x6"s or something big use 2x4 made into a tee shape so it pushes the hay out. Loosen the tension all the way.
2016 Audi A6 AWD Sedan (A64557)
2016 Audi A6 AWD...
2020 Inifiniti Q 50 Sedan (A64557)
2020 Inifiniti Q...
UNUSED 2023 JCB S3246E ELECTRIC SCISSOR LIFT (A65053)
UNUSED 2023 JCB...
(2) SUPER SAVER HEATERS & PARTS (A64278)
(2) SUPER SAVER...
BOUROUGHS 300 GALLON SPRAYER (A64278)
BOUROUGHS 300...
2021 CATERPILLAR 279D3 SKID STEER (A65053)
2021 CATERPILLAR...
