Rotary Cutter BUSH HOG BH27 arrived
   / BUSH HOG BH27 arrived #1
xring100
Livingston County, Michigan
Kubota M8540, ZD1211 60"
Took delivery of my new BH27 today and took it on a trial run.
Here it is still on the lot.
Unloading it had to use my snow mobile trailer my others are not wide enough
Got about half the front field mowed and the rest of the western half of the property
   / BUSH HOG BH27 arrived #2
Looks petty stoat, like how it came with chains. Land Pride charges extra for that.
Bush Hog charges extra as well he told me how much before ordered it but its not listed on the receipt seems to me it was close to $300. I like that its orange and not red. After having been hit in the back and head with small pieces of shrapnel using my buddies i decided to order the chains. Ive heard the rubber Shields don't last as long.
Sides are 1/4" it was a tough call between landpride and bush hog. If i had known the BH had a Chinese gear box i would have checked out where the land pride was made
   / BUSH HOG BH27 arrived #4
I think you done good! My stock guard was a piece of steel on the back.
Thanks so far I'm very happy. I made sure the slip clutch was adjusted and working properly the dealer did not touch it on prep. Also checked to make sure it had oil.
   / BUSH HOG BH27 arrived #7
Make sure you write down your spacing on the slip clutch to readjust every year
   / BUSH HOG BH27 arrived #8
That's a real nice lookin cutter. You oughta get alot of good service outta that one.
   / BUSH HOG BH27 arrived #9
Nice looking cutter. Don't sweat the China box, that's about all there is to be had on anything.
   / BUSH HOG BH27 arrived #10
I've been really happy with our Bush Hog, not one problem and the freight was cheap to Alabama... :)
1985 Miller Wildcat 350-D Welder (A54811)
1985 Miller...
2016 Ford Fusion S Sedan (A53424)
2016 Ford Fusion S...
Yellow Steel Diamond Plate (A55758)
Yellow Steel...
1983 INTERNATIONAL S SERIES WATER TRUCK (A57192)
1983 INTERNATIONAL...
2020 HINO 268 26FT NON CDL BOX TRUCK (A54313)
2020 HINO 268 26FT...
70pc. 12ft.x 3ft. Black Metal Roof Panels (A55758)
70pc. 12ft.x 3ft...
