john deere welderator
/ john deere welderator #1
cowski
Alabama
cx70,5510,4630,5005, 108s
john deere is now offering a welder,generator and air compressor .it costs $4775.it is powered by a 14 hp subaru gas engine.170 dc amps.5000 start up watts and 175 psi air pressure.sure would have been nice to have when i was row cropping.
/ john deere welderator #2
What a rip off! Booooo!
i guess you would rather have a miller for 12000.
/ john deere welderator #4
Nah. For less money I got this. 23hp kohler, 12,000 watt and 300amp.
/ john deere welderator #5
I am sure they will sell them. Space in the service truck is at a premium.
/ john deere welderator #7
Mike how do you like that new machine? :drool:
Oh im loving it bud! I haven't had a chance to do a full review on it yet cause when im home all its been doing is making me money :) all the farm boys been haying by me and breaking everything. I never got my Ln 25 yet, and after I got my last issue resolved my tig machine took another crap. 2nd time in about six months and I said screw it ill fix it again another time and keep it as a backup and my lws gave me a deal on a new syncrowave 210 that I just picked up last night. It got late on me quick and never got a chance to use it and I gotta leave town for a while so cant even give a review on it yet. Ughh! I went with a inverter because my electrician friend swears it's the cutting back on the grids that's screwing up my old machine. Miller states this machine is built to handle a dirty power supply. Can't wait to try this dirty girl :D
/ john deere welderator #8
I would go with either an auction engine drive, and an electric air compessor strapped on top, or a used generator with air compressor and a nice inverter. I could put the whole rig together, that would work better, for under a grand...
/ john deere welderator #9
Totally agree. And if you put it together yourself, and are installing it in your service truck, you'd probably find a real nice location for an oversized air tank for the system. Like underneith, or on top of the cab where you dont want a lot of weight. Plumb it with hose. Put on a quick connect to fill the tank at home every morning, so actual service stops may not even require the electric air compressor to run much.
/ john deere welderator #10
I like the ideal of a welder, generator, compressor combo machine. Dont know that i really need one, but would probably jump at the chance to buy a good used one. When you think about it a little bit, most engine drive welders i have ever seen can be used as generators. The welder hooks to the tail shaft of the engine, why couldnt you just add a compressor to the flywheel side of the engine and a couple of those contractor compressor air tanks to just about any brand of welder, and make your own combo. I probably wouldnt go thru all that trouble, but it should be easy enough to be done if you really have the need for it.
/ john deere welderator #11
agreed. it's a compromise unit. way overpriced. you could have a better genny, welder and air comp.. seperate for WAY less money. or even if you went to a combined welder genny.. like a hobart 10k unit.. and then tossed in an air compressor.. etc.. and saved a grand+
/ john deere welderator #12
My 10 cfm 220v compressor was about $500, add in a $1k used engine drive (ranger, bobcat, trailblazer, ect) and you could be in bussines for under 2 grand..... And I would rather have that rig..... LOL
/ john deere welderator #13
I'd like to know where you find good used Rangers, Bobcats and Trailblazers for $1000? When I was looking a few years ago, all the used ones were only about $500 less than a new one. I ended up finding a 1961 SA200 Redface for $500 and spent another $800 on a new carb. and rebuilt mag. Bought some used 2/0 cable from Red-D-Arc for $2/ft as well as a stinger/whip and ground clamp. A little over $1500 for everything. I could double my money but I needed a welder. A welder/generator would have been nicer but I have a smaller generator than runs all my power tools. I think the cheapest I found in a newer combo was around $3000.
/ john deere welderator #14
I have seen a few around here. I guess because they are in lower demand here, prices are lower. They also were slightly older units... LOL
I have seen the old airco wasp units for under $500... That would be a nice farm welder.
iDrive TDS-2010H...
Towable Generator (A60352)
Towable Generator...
2004 BMW 325ci Convertible Coupe (A62613)
2004 BMW 325ci...
John Deere 348 Square Baler (A65579)
John Deere 348...
2019 Chevrolet Silverado 1500 Crew Cab 4X4 Pickup Truck (A60352)
2019 Chevrolet...
2022 Great Plains 3000TM Turbo Max VT (A66285)
2022 Great Plains...
