Where is the serial number for my Ford 600
   / Where is the serial number for my Ford 600 #1
RileyJ
Onondaga, MI
MF 165
The manual says left side front of the transmission case but I am not seeing it. Am I looking for numbers in all the wrong places?
   / Where is the serial number for my Ford 600 #2
Left side of tractor (when seated facing forward) just behind starter. There is a flat area with two holes. On the flat area on top there should be two rows of numbers. Top line is model #, bottom line is serial #.
Thanks. I had glanced at it and didn't believe it could be there. Thanks again.
   / Where is the serial number for my Ford 600 #4
many times years of paint jobs obscure it. also on 59+ machines with diesels.. the area is many times pitted from battery acid..
post back if you need more help
Thanks I have now found it with your help. I feel much better now. Thanks for the help
   / Where is the serial number for my Ford 600 #7
inquireing minds want to know.. :)
   / Where is the serial number for my Ford 600 #8
This data is on a horizontal flat area on the transmission where the starter is bolted on. Mine is a 641.
2022 FREIGHTLINER CASCADIA SLEEPER (A56129)
2022 FREIGHTLINER...
2020 FREIGHTLINER CASCADIA 126 SLEEPER TRUCK (A59575)
2020 FREIGHTLINER...
2014 International Derrick Digger Truck (A55973)
2014 International...
Deere 310L (A53317)
Deere 310L (A53317)
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59575)
2019 FREIGHTLINER...
1996 Timpte 46ft Hopper (A56436)
1996 Timpte 46ft...
