Buying the Right Size Box Blade
   / Buying the Right Size Box Blade #1
ctryan5733
Adamsville, Tennessee
Mitsubishi D1800
Can anyone tell me what size box blade I should be buying for my tractor? I have a Mitsubishi D1800. It has a category 1 3 point hitch. It uses a 4 ft bushhog so I'm thinking the box blade should be 4ft as well to not over do it. But it's much easier to find 5 ft box blades for sale on Craigs list and I can't find many used 4 ft box blades.
Thanks,
Craig
   / Buying the Right Size Box Blade #2
How wide are your Mitsubishi rear tires?
I trust the Mitsubishi has four wheel drive.
You need 125 pounds per foot for a box blade to cut well. So if your rear tires are about 48" outside-to-outside, that means about a 500 pound box blade. It is rare for a tractor to have sufficient power to be able to drag a full box blade wider than the rear tires. A full box blade is one implement that will make your tractor grunt.
If you buy a box blade too light it will bounce along the top of the ground, rather than cut the dirt.
My Kubota B3300SU has a rear tire width of 59". I pull a 60", 630 pound Bush Hog (brand) Rollover Box Blade.
In Photo #1 it is moving dirt. In Photo #2 the rippers are down and it is tearing out wild grape roots.
Here are some archived T-B-N threads for 48" Box Blade:
http://www.google.com/#bav=on.2,or.r_qf.&fp=6e62cf50a2f48705&q=48"+box+blade+site:tractorbynet.com
The Mitsu is NOT 4 wheel drive unfortunately. Do you mean for me to measure the width of the wheels themselves or the distance between the wheels in the back?
   / Buying the Right Size Box Blade #4
I believe Jeff means measure the distance of the rear tire stance, i.e. outside rear wheel to the other outside rear wheel; in other words, the maximum width of the tractor.
Good luck!
   / Buying the Right Size Box Blade #5
ctryan,
What do you intend to do with the box blade? Move small amounts of dirt to level an area or try and dig ditches and pull full loads of dirt over large distances? I used a 5 ' woods BB5S-1 280 lbs with my BX1850. Yes if I tried to pull full loads of dirt it would spin out but I liked the blade being wider than the tractor for doing leveling or grading type work. Like Jeff stated it is to light to really cut into hard packed dirt.
Another consideration is how much weight will your tractor lift on the 3PH.
   / Buying the Right Size Box Blade #6
You definitely do NOT want a Box Blade wider than your rear tires, measured outside-to-outside. You MAY have to pull the Box Blade half full in order not to lose traction. No big deal, it will just take you a little longer. Soil moisture when you work will have considerable influence.
I presume your rear tires are 48" or less wide, outside-to-outside. There is hardly any information on TractorData.com site for Mitsubishi D1800, which is unusual.
"oldnslo" has a valuable suggestion to check lift capacity of your 3-Pt. Hitch.
http://www.tractordata.com/farm-tractors/003/6/9/3691-mitsubishi-d1800.html
   / Buying the Right Size Box Blade #7
I used a 5 ' woods BB5S-1 280 lbs with my BX1850. Yes if I tried to pull full loads of dirt it would spin out.
Do you use your Box Blade in 2-WD or 4-WD? What is your Box Blade weight per foot?
Tracton is going to be an issue with the Box Blade for the Thread Originator. What is your opinion of how a 48" Box Blade will pull for him with 2-WD?
   / Buying the Right Size Box Blade #8
Do you use you Box Blade in 2-WD or 4-WD?
Normally 2-WD as default in loose dirt or slippery conditions I would use 4-WD. I also live on flat ground and rarely try to pull a full load of dirt. I used this and the FEL to back fill and grade around my addition, core out drive ways to out buildings, spread gravel, etc. Personally I like having the blade wider than the tractor but I also don't have concerns about going between buildings or close set trees.
   / Buying the Right Size Box Blade #9
Everything Attachments makes a 54 inch Box Blade, which is just in between the 48 inch and the 60 inch models that are most common. That size, being wider that your rear stance, might be just what you are looking for depending on what you anticipate doing. Its weight and cost could be a factor when compared to other BBs. You probably can't go wrong with a 48 inch model however. Cheers, Mike
Jeff,
The width from outside wheel to outside wheel is slightly less than 48 inches. So a 4 ft box blade seems to be what I'm going to need. I want to use it for redoing my driveway. So I will be wanting to dig across it a little bit to bring up the current gravel and then after adding more gravel, I will need to spread the new gravel over it and make it look nice. My driveway is mostly flat, with a slight dip at one point. It's pretty long though, about 1/4 mile long. I will also use the box blade I would guess to dig some trenches at one point if I can power it to do that with my 2 WD tractor. And spreading dirt and things too.
You mentioning the weight I need of about 500 lbs will help me shop for one, however I am not sure I will be able to find a 4ft box blade that weighs 500 lbs, but I might be wrong on that. Hopefully I am.
Mini Margaritaville Truck (A55853)
Mini...
UNUSED FUTURE FT-FR60 60" SIDE SHIFT FORKS (A57193)
UNUSED FUTURE...
Rotadairon RD100 III Rotary Soil Tiller Tractor Attachment (A55851)
Rotadairon RD100...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A55973)
2021 Ver-Mac...
15ft Batwing Rotary Brush Cutter Tractor Attachment (A55851)
15ft Batwing...
Utility Trailer (A52377)
Utility Trailer...
