Operating temp CK27
/ Operating temp CK27 #1
whitet101
North Shore Ma.
Kioti CK27HST
I purchased a CK 27 HST over the winter. Even after a few hours of use moving snow, the temp gauge hardly budged. when I questioned the dealer about it he said in the summer it would move higher.
Well its summer now and the gauge still only moves a tiny bit.
I just wanted to get some opinions on proper operating temp and if "running cool" is a problem.
Thanks
/ Operating temp CK27 #2
I have a CK30hst. As far as Winter, if you idle for at least 5 minutes after working the tractor for a while, the engine will cool down. This is normal for a diesel. But when I'm actively plowing at 2000rpm or more, the engine stays warm even at 10'F air temp. In the Summer temps, it's always warm when working the tractor and will stay warm at idle. By warm, I mean the temp gauge is in the middle. I never took an actual temp reading but hoped the gauge was correct. Yours may be at operational temp but either the gauge or sending unit is faulty or the thermostat is stuck open. Do you have a way of getting a close reading on the temp by using a non-contact temp gun or with care, open the radiator cap and put in a thermometer? I'll have to look in my service manual for the correct operating temp. Normally, running cool won't hurt the engine but there will be a little loss in power due to inefficient combustion.
/ Operating temp CK27 #3
If the radiator warms as soon as you start the engine then the thermostat may be stuck open or there is a defect in the system.
The radiator should stay cold until the engine reaches operating temperature.
My 1720 Ford would not warm up so I contacted my dealer and they said there was a recall which required replacing the thermostat housing.
Any engine needs to warm up to operate properly especially diesels which run cooler than gasoline engines otherwise contaminates (moisture) will build up in the oil which will cause premature wear or failure.
90cummins
Thanks, Vic
I will check the operating temp in the manual and prob the radiator.
90cummins
Thanks for the reply, I was worried about moisture buildup. The radiator touch test is an easy first step. I do think it needs to be addressed.
Michael
/ Operating temp CK27 #6
Where does the gauge read at it's highest?If you're going to open the radiator cap, I suggest doing it prior to starting the tractor. See if there is flow of coolant by the filler neck, and make sure your overflow jug is full to the fill line as a matter of coarse. Opening the cap when it's running can be a problem, depending on what's wrong, you can get scalded by hot coolant. For now don't trust the gauge reading until you have investigated the system's function.
/ Operating temp CK27 #8
On my DK, the temp climbs to the bottom of the "OK" range and stays there. The climb is slow unless under load, like mowing. It is not good for an engine to run cold so find out if you have a bad thermostat or a bad gauge. The Harbor Freight IR thermometers are cheap and handy for this but you can probably sort it out using methods described above.
/ Operating temp CK27 #9
Pic of gauge at full operating temp note the tach View attachment 331353
NO WAY! Totally bogus, if that is at full operating temp. My DK reads between the two dots in the middle of the gauge, and has for over 535 hours since 2010.
What is the situation with the coolant temp inside the radiator filler neck? Stick a thermometer in there!
/ Operating temp CK27 #11
My temp gage, when working the tractor, will stay middle gage around the two 2 white dots that are shown in your picture. When at idle for 5 minutes or longer, in cool weather, the indicator will lower just below the lower white dot. I suspect either your gage is not reading correct, the thermostat is not regulating stat temperatures, or it is bypassing.
Talked with the dealer yesterday, its being picked up this week, will update.
Thanks for all the info.
/ Operating temp CK27 #13
I had the same problem--gauge never moved at all. When I had the 50 hour service [January], the dealer
said there were some bad sending units which he replaced under warranty. Ever since it runs
between the dots or just below [idle].
Thanks. Good info. I was thinking that was the problem. But I put a temp probe in the radiator at operating temp and it was what I think is low at 149 deg. I assume the thermostat is at 170 or more. Maybe the radiator is dropping the temp by 25 deg. Anyway. Should know this week.
/ Operating temp CK27 #15
If the gauge does not move at all, it sounds like the sender like retired guy said. I usually ground out the wire and it should go all the way to hot, but that is what warranties are for. CJ
Update:
Dealer came by and discovered corrosion on the connector at the sending unit. he changed the sending unit and cleaned the corrosion on the connector and was able to get the temp. guage to operate properly.
He has ordered a new wiring harness and will install that when it arrives.
So, I am glad to see the engine has been running at the proper temp. the whole time. Just not being reflected at the guage.
However, a bit concerned about why a brand new tractor has corrosion in the wiring. I hope this doesn't make for problems down the road.
/ Operating temp CK27 #17
Update:
It sounds as if the dealer is doing the right thing. Glad to hear the warranty program is working well.
2019 CATERPILLAR 299D3 XE SKID STEER (A65053)
2019 CATERPILLAR...
2026 SDLANCH SDLMG1220F Galvanized Metal Livestock Shed (A64194)
2026 SDLANCH...
2015 BMW X1 SUV (A64557)
2015 BMW X1 SUV...
2014 Crossroads RV Elevation T/A 5th Wheel Toy Hauler Travel Trailer (A64557)
2014 Crossroads RV...
New/Unused 20 Ton Hydraulic Jack (A65583)
New/Unused 20 Ton...
New/Unused 20x30 All Steel Carport (A65583)
New/Unused 20x30...
