Bearcat 554 Chipper & i-Match top link
   / Bearcat 554 Chipper & i-Match top link
Just an update here. I drilled a couple holes in some flat stock and bolted them on. Then I checked to make sure that it would work because there isn't much room for the i-Match hook in there. A couple of welds across the top hopefully will keep everything from moving around.
Since I don't plan on using the blower I made a cover for the pulley that powers the blower and a deflector for the discharge screen.
   / Bearcat 554 Chipper & i-Match top link #12
Looking good BT!
   / Bearcat 554 Chipper & i-Match top link #13
View attachment 331223 View attachment 331224
Nice job, Bro...you have motivated me to get off my dead *** and do something!
So, why aren't you going to use your blower? My Woods 5000 (same as your chipper/shredder) doesn't have one...I'd like to get a blower, but not a thousand bucks worth of "like".
   / Bearcat 554 Chipper & i-Match top link #14
I would have loved to help you with that before you moved!
FYI, the shackle is only a 2.5" extension, not 3.5 like I wrote in post 1.
The blower I had years ago had 3/4" holes in the screen and the fan would plug up constantly when shreading and this new one has 1.5" holes in the screen. So I just figured it would plug up even more -- when shreading. When the blower plugs up, it is a Bear Cat to unplug because of the weight. I think that is how it got it's name.
When chipping, the blower workes flawlessly.
2017 Rogator RG1300B Dry Fertilizer Applicator (A55315)
2017 Rogator...
1994 International 3800 Bus (A54814)
1994 International...
2015 Ford F-550 Ext. Cab Enclosed Service Truck with Liftgate (A53422)
2015 Ford F-550...
UNUSED PABREAK GCC56-2 PRONG HAY SPEAR (A57193)
UNUSED PABREAK...
2005 Autocar WXR Heil Rear Loader Garbage Truck (A55852)
2005 Autocar WXR...
2017 Ford F350 (A55973)
2017 Ford F350...
