If you have small acreage and thinking of cutting hay... Drum Mower
   / If you have small acreage and thinking of cutting hay... Drum Mower #11
That's a really nice field.
Drying time with the Drum..... I cut that alfalfa Monday about noon.... turned it Tuesday about 1 PM.... Turned it today Wednesday.... Planning on baling tomorrow, Thursday..... 3 days from cut to bale.... the thin layer of hay dries very quickly.... When my neighbor cut my hay with a 14' JD MoCo it took 9-12 days to dry.... the swath was about 8-10" thick..... The water is on 8-10 days earlier... and the crop is growing again.....
   / If you have small acreage and thinking of cutting hay... Drum Mower #13
Are you tedding or raking to turn it?
   / If you have small acreage and thinking of cutting hay... Drum Mower #14
We currently use a 9' NH Sickle MoCo set to leave as wide of a swath as possible (~5'). With that, we can cut on Wed or early on Thu and bale on Sat and we often dont get more of a window between rain than that, so going to something that would lengthen our drying time would be suboptimal.
Aaron Z
Aaron, evening..... I don't think you could cut that stand of alfalfa with a sickle... I tried for 2 years with a 7' sickle bar... It was too tangled and balled up.... It was a PITA.... Cutting grass, I can see 2 days drying time..... no way in an alfalfa stand like I have.... Anyway, thanks for the comment on my method of cutting and drying being "suboptimal".... This alfalfa stand was previously cut with a 14" JD discbine mo/co and took 9-12 days to dry...... I guess you missed that post... Have a very good evening.... Dave
Aaron Z
   / If you have small acreage and thinking of cutting hay... Drum Mower #17
This isn't a sicklebar mower (like a Ford 501), its a New Holland 469 Mower Conditioner (like this one: http://www.tractorhouse.com/listingsdetail/detail.aspx?OHID=7758901 )
The pickup reel pulls the crop off of the sicklebar, then runs it through the crimper rollers. It works well as long as you dont try to run over a already cut windrow, but you cant go overly fast with it.
9-12 days to dry? In our area we have a hard time getting more than 3 days in a row with under 30% chance of rain (our measure of when we will cut) so that wouldn't work for us (hence my suboptimal comment).
If your neighbor took 14' swath of heavy alfalfa and reduced it to a 4-5' windrow, I can see why it would take a while to dry. We found that making a 3' windrow from a 9' swath took 3.5-4 days to dry while a 6' windrow from the same swath takes 3-3.5 days to dry.
Aaron Z
aczlan, Morning..... I think that NH 469 would cut my alfalfa.... With the "sweeper" or what ever it's called, it would keep it from balling in front of the knives.... Nice unit.... Where I'm at, there ain't much in the way of "choices".... too far from civilization.... I guess that's why I had to get the drum mower from Tennessee.....
Dave
   / If you have small acreage and thinking of cutting hay... Drum Mower #19
The pickup reel is the key. Otherwise it would do like our Ford 501 does and ball up in heavy/tangled stuff.
Aaron Z
   / If you have small acreage and thinking of cutting hay... Drum Mower #20
What do those drum mowers cost?
7021 (A55851)
7021 (A55851)
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
2014 Ford Fusion Passenger Car, VIN # 1FA6P0H77E5377755 (A56859)
2014 Ford Fusion...
2014 MAGNUM PRODUCTS LIGHT TOWER COMBO (A58216)
2014 MAGNUM...
New/Unused 6ft Quick Attach Brush Cutter (A57454)
New/Unused 6ft...
(4) 275/60R20 TIRES (A58374)
(4) 275/60R20...
