Polaris Ranger Crew Stuck in Swamp Two Weeks Now....
   / Polaris Ranger Crew Stuck in Swamp Two Weeks Now.... #81
Actually harbor freight winches were tested against warn and a few other big names by FOUR WHEELER magazine and the Harbor freight winches won ! What they found was the user's were running the winches at full load and kept there finger on the trigger until they all burned out at some point ,When used correctly in 20-30 second bursts with a few minute cool down in between full load pulls most all of them were the same ! You can't run any winch at full load for long .
We get those same basic winches here at Princess Auto. They are complete and utter shat. A winch is something you need to work when you need it. Those cheap winches cant be relied on. Seen it first hand.
   / Polaris Ranger Crew Stuck in Swamp Two Weeks Now.... #82
I agree! Unless my Warn lets me down, I will stick with Warn. Runva would be my other choice.
   / Polaris Ranger Crew Stuck in Swamp Two Weeks Now.... #83
I would not give up hope yet. Yes you may some problems to deal with BUT I seen ATV's come back from worse. Just make sure your belt housing/clutch assembly is free and clear of any debris. That is not a cheap part, also rather important....
Good luck
   / Polaris Ranger Crew Stuck in Swamp Two Weeks Now.... #85
OP - have not read the whole thread, anyway of getting something bigger close to pull it out?
I have two neighbors with a dozer and BobCat, but they can not get in with current conditions.
Yesterday I spoke to a local company that specializes in removing items from swamp and mudd.
They are bring three if their equipment out Friday and decide what to use after they look at the situation.
Two great guys who farm part of my land are returning to help with two Honda 4x4 ATV.
My brother in law us coming with Rolleze Wheel cart plus boat straps with Rachet, boat rope and boat pulleys.
They plan to set up between the trees and lift the rear to clear the mud and front to clear the stumps. Then pull or lift it out forward hopefully.
The company has an excavator which they are bringing in case they can get it in.
The guys who got it stuck and then messed it and other things up were brothers who I trusted as one worked for me off and on at the farm the past two years. The other is his older brother who headed the hunters I let hunt. I found they drink much heavier than I thought. I was out of area when they tried to recover each week.
I finally told them to stop and do nothing until I am there. I have not seen or heard from them since.
   / Polaris Ranger Crew Stuck in Swamp Two Weeks Now.... #87
Good luck!! Hope you get it out fairly easy. A good wash, fluid change, drain the CVT belt cover, should be all good. A few days to dry out is all it should need.
   / Polaris Ranger Crew Stuck in Swamp Two Weeks Now.... #88
If you actually can lift the wheels above ground level, slip some plywood under it. Even if the plywood sinks a bit and cracks some, it will give you more solid footing than much and tree debris. But getting the wheels off of the ground will be some lifting, but not impossible.
   / Polaris Ranger Crew Stuck in Swamp Two Weeks Now.... #89
I agree. 4 sheets of plywood could make your life much easier if you are able to lift enough to get them underneath it.
Aaron Z
   / Polaris Ranger Crew Stuck in Swamp Two Weeks Now.... #90
I had a 10 000lbs ramsey explode on me, really lucky. I son should have died that day. We were very lucky. The spoon launched about 70' from the original location. The planetary gear shot inches away from him. he was standing in the "safe zone." They can all fail.
2017 Chevrolet Sonic Premier Sedan (A55853)
2017 Chevrolet...
2016 Ford F-450 Cab and Chassis Truck (A51692)
2016 Ford F-450...
CATERPILLAR 80" QUICK ATTACH BUCKET (A51406)
CATERPILLAR 80"...
UNUSED FUTURE CL100 40" - 10" CLAMP GRABBER (A57193)
UNUSED FUTURE...
UNUSED 1RANCH 1RETC HYD THUMB CLAMP (A57193)
UNUSED 1RANCH...
2013 Ford Taurus Sedan (A55853)
2013 Ford Taurus...
