Replacing Rotary Cutter Blades...Anti-Seize on Bolts???
   / Replacing Rotary Cutter Blades...Anti-Seize on Bolts??? #1
Turbys_1700
Elite Member
Balls Creek, NC
New Holland t4.75
While I was bush hogging the other day I broke off one of the blades...
Needless to say the vibration in the hog was pretty bad...
I brought the tractor home and removed the blades without any issue at all...
Evidently someone else had replaced the blades at one time or another and the bolts were easy to remove with a 3/4 drive cheater bar and 1-3/4 socket...
The blades are in really bad shape...
I am going to replace all 4 but the bolts are in very good shape...
For those of you that have replaced your blades, did you use anti-seize on the bolts?
I have heard both pros and cons on this issue...
I am leaning toward putting it on the bolts during the re installation...
Any opinions would be appreciated...
   / Replacing Rotary Cutter Blades...Anti-Seize on Bolts??? #2
Absolutely put never-seize on the bolt threads and bolt shank where it fits snugly in the blade bar.
Note: Sister sent me a link to a Hickory Record article about flood damaged roads, looks like a mess down there!
   / Replacing Rotary Cutter Blades...Anti-Seize on Bolts??? #3
+1:thumbsup: I have been doing what RickB suggests,using nickel never-seize, for over 20yrs. I have had zero problems.
2017 Mack GU713 Granite Tri-Axle Dump Truck (A49461)
2017 Mack GU713...
40ft Shipping Container (A49461)
40ft Shipping...
2004 JOHN DEERE 5205 TRACTOR (A51406)
2004 JOHN DEERE...
2016 WINNEBAGO SCORPION 4014 5TH WHEEL CAMPER (A50854)
2016 WINNEBAGO...
2018 Skyjack SJ1056TH 10,000lb 4x4 Rough Terrain Telehandler (A49461)
2018 Skyjack...
2019 NEW HOLLAND TS6.130 TRACTOR (A51406)
2019 NEW HOLLAND...
