Polaris Ranger Crew Stuck in Swamp Two Weeks Now....
   / Polaris Ranger Crew Stuck in Swamp Two Weeks Now.... #21
Around the axle works best as long as there are no rubber boots to be damaged there.
   / Polaris Ranger Crew Stuck in Swamp Two Weeks Now.... #22
How heavy was the winch that broke? The rear diff is probably full of mud.
I would be afriad to wrap a strap around the axles because it may bend them.
Too bad you don't live closer to me, I'd help you out.
   / Polaris Ranger Crew Stuck in Swamp Two Weeks Now.... #23
Don't strap the axles, they are cv shafts...
   / Polaris Ranger Crew Stuck in Swamp Two Weeks Now.... #24
An axle is an axle. You can call it a CV shaft of you want but it's still an axle to me. This thing is seriously stuck. It's not going to be a warm and fluffy thing to get it out.
   / Polaris Ranger Crew Stuck in Swamp Two Weeks Now.... #25
They are not inside of a tube.. DO NOT hook anything to them!!
Get a shovel and start digging!!
   / Polaris Ranger Crew Stuck in Swamp Two Weeks Now.... #26
What if you hooked on the axle and it bent and cracked the front diff. Axles are usually hollow.
   / Polaris Ranger Crew Stuck in Swamp Two Weeks Now.... #29
Remind me not to take you guys with me if I ever get stuck.
   / Polaris Ranger Crew Stuck in Swamp Two Weeks Now.... #30
It would be nice to get something with a decent winch on it back there. Do you have a blazer/jeep/bronco with a 8000 to 12000 lb winch? Tie it to a tree and start pulling away. Perhaps you could buy, rent, or build a chainsaw winch. Or just go to Harbor Freight (with coupon), and buy a good winch, build a mount to allow you to attach it to a tree, and carry it down there.
If you have something jammed in the rear axle, perhaps it would be better to try to try to pull the Ranger out backwards.
20205 Lucky Dak Electric Scooter (A55853)
20205 Lucky Dak...
GLEDHILL SPREADER (A52707)
GLEDHILL SPREADER...
2011 Ford F150 (A55973)
2011 Ford F150...
2003 Big Tex 10PI...
Mobile Mud Hog (A56469)
Mobile Mud Hog...
23018 (A55758)
23018 (A55758)
