567 Baler is here!
/ 567 Baler is here! #1
hoffmtim
God's Country
2013 John Deere 5093e; 1949 John Deere MT; 1972 John Deere 800 windrower, restored; 2001 567 John Deere baler; 2013 CaseIH Farmall 55a MFWD
The 567 baler finally showed up today. Looking forward to putting it to work with the 3rd cutting of Alfalfa!
IMG-20130802-00351.jpgIMG-20130802-00352.jpgIMG-20130802-00350.jpgIMG-20130802-00349.jpgIMG-20130802-00348.jpgIMG-20130802-00347.jpg
/ 567 Baler is here! #2
thats 1 nice looking baler.
/ 567 Baler is here! #3
That is a sweet baler, will produce some nice bales, pics are a must when being used.
Thanks. Its a 2001 model, was traded in on a 569 model at the dealership I bought the 5093e from. Bought it for $5950 and had them run it through the shop. They replaced chains and sprockets that were wore or getting slack (including the big chain), checked and replaced bearings as needed. I told them to replace what was needed, I didn't want to bring it back to the shop. The baler has 30k bales through it, but came from a custom guy who took really good care of it. No dents, paint is good as you can see, a few minor weld spots down around the pickup area but all in all I'm pretty satisfied. There is even a moisture tester on the baler with a hand unit.
Repairs came to $2200, so I've got $8200 into the baler. I do only 100 bales or so a year, so it should last me as long as I want to bale.
Yeah, even the sales guy was disappointed in the white rim. We'll be on the look out at farm sales to replace it....
/ 567 Baler is here! #7
Wait until you see the absolutely perfect bales that will make. The first few don't count.
/ 567 Baler is here! #8
Thank god for that, mine look like a funnel (can't seem to chase the bars fast enough on the monitors, my sweeps left to right and right to left are too slow.)
/ 567 Baler is here! #9
IMHO $8200 is dirt cheap especially compared to NEW price. The fact it doesn't have surface wrap affected it's resale value.
/ 567 Baler is here! #10
Why don't you pull up the correct channel on the monitor and change the bars response speed or rake a bigger windrow?
/ 567 Baler is here! #11
tx jim we have a 2006 567 mega wide that we spent $2800 going through.an the guy in the shop that went through it wanted to buy it from us.an i figure if we wanted to we couldve made a $6000 profit.
/ 567 Baler is here! #12
Nice baler,should last you a long time. White wheel adds character...
Corey as for the bale shape,it will come to you, wont even use the level lines after awhile... I get an ugly duckling every now and then but my monitor does even have the level option in it. I call them after dark bales.
/ 567 Baler is here! #13
Did your '06 567 have surface wrap? I own a '05 467 with surface wrap that I wouldn't take $15K for.
/ 567 Baler is here! #14
no its twine only with 2600 bales on it when we bought it.an it hadnt baled hay in 3 or 4yrs.when it got out of the shop we had $19,800 in it.
/ 567 Baler is here! #15
bigbull338
I see no reason that a baler that's only baled 2600 bales would need going through a dealership shop to the tune of $2800. My baler with 16,000+ bales on it hasn't had near that much spent on it.
/ 567 Baler is here! #16
bigbull338
the baler hadnt been taken care of the guy we got it from just baled hay with it.an he didnt grease it or take care of it.the only thing he did right was keep it in the barn.had a pick reel bearing out an 2 or 3 other bearing out 2 or 3 reel teeth out the wiring had been messed with hooking the baler to the monitor.the sprokets were bad.the big chain on the sprokets wasnt right.so all of that was replaced.
/ 567 Baler is here! #17
That's what I did and turned it up to max and that made the difference, thank you for that tip.
/ 567 Baler is here! #18
It's hard to believe the sprockets were worn out with just 2600 bales. The previous operator must have been running the pick-up attachment way too low to knock out the cam brgs.
Finally got to use the 567! First picture is the first bale produced :( . A little too hour glass looking. After that, they got a lot better. Everything worked well, except my bale trak would show low voltage and half of the bales I had to manually start the tieing. Gonna call the dealer on Tuesday after the holiday and try to determine if the actuator is causing the problem (certainly my NEW 5093e cant be the problem!). As long as low voltage stayed away, everything worked very well.
This is exactly why I wanted to wait until 3rd cutting to dry run it. Small amount of hay to deal with should problems arise. Put up 13 bales on the 18 acres with 3rd cutting, 80 total for the year. July got real dry here. BTW, it was 93 degrees and very humid when baling, man that air conditioned cab sure made my day!
/ 567 Baler is here! #20
Hoffmtim that takes skill to get the HR glass look:D,never have baled one like that,usually just get a slight cone shape or high in middle. As for the low voltage sound like wiring,maybe bad connection since it wasnt all the time? I have very few days in hay field everything goes smooth.
Look good:thumbsup:
WOODS 3120 BATWING MOWER (A60430)
WOODS 3120 BATWING...
2002 CHEVROLET 3500 FLATBED TRUCK (A60430)
2002 CHEVROLET...
14in Digging Tooth Bucket Excavator Attachment (A64194)
14in Digging Tooth...
(2) 15X19.5 TIRES ONLY (A64281)
(2) 15X19.5 TIRES...
Ripper Tooth Excavator Attachment (A61567)
Ripper Tooth...
2004 Dodge Ram 1500 Crew Cab Pickup Truck (A61573)
2004 Dodge Ram...
