Stopped in to a local clutch and brake re builder, looks the bill isn't going to be as bad I I thought, if I need a new clutch that is. 400 for a complete clutch rebuild or 150 for a clutch disc installation.
No, I was just checking prices. I didn't want to tear the tractor apart, and not be able to afford a new clutch right away. I can still move the machine right now. Once I tear into it, it won't go back together until it is fixed, and I really don't see anyway around it. I do not see an inspection cover/hole. So the way it appears I'm going to have to split the tractor to see even what was wrong.So You had a tired clutch? The price is not bad specially if it is dual clutch? Take a pic of the old clutch disk and pressure plate so we can tell what it is. If you have single clutch for sure I'd suggest all new throwout bearing, pilot bearing , disk and pressure plate. Last weekend I changed my son's Mitsubishi eclipse clutch for $100 combined with 16 hrs of pure agonizing pain in the neck sweat equity labor.
JC,
I can't even start on it until I get my Moms Honda Accord back together. pulled motor and trans, putting back a new rebuilt short block. So I've still got a ways to go on that yet. Working full time, family duties doesn't allow for alot of extra time during the week. I'll get it though, I'll be sure to post my findings.
Thanks for that bit of advice, I am having difficulty finding any real info on the web. Like everything with this tractor is a secret. Unless I buy the service manual.I understand, one thing at a time. If you can put in a short block and do the a valve job on the old head then you're more than capable to do a clutch job on a smallish tractor. Even without inspection hole you can check and adjust throwout bearing to the fingers on the clutch pressure plate. I'd suggest you'd put a clear " witness mark" exactly where it is on on the adjustment clevis for your clutch. Study the mechanism and press the clutch as many time as you need to understand the linkage mechanism. You can adjust it forward and backward knowing where your original witness mark was. if you make it too lose then you can disengage clutch, make to tight and you're riding the finger (don't want to keep it there). A bit of trial and error and you might find the sweet spot where you can disengage the clutch fully without riding the fingers on pressure plate. You might get a few more years used of clutch disk left. All of this would not need a lot of time , expense and tractor split. Those prices are probably for parts only as find it difficult including the labor. You can do fine on buying clutch parts from Fleabay.
JC,
Found the inspection hole. LOL, but I have to remove the front loader to get to it.
I found I need to replace one of my hydraulic quick connect couplers on my loader in order to remove it. Haven't made to a spot to pick one up yet.
Yes it has pedal play. wasn't there when I first got on it today. I was told once that you aren't supposed to free wheel these tractors. I had backed up a hill with a heavy scraper blade in the bucket. When I was going from reverse to 1st, I had my foot on the clutch, and didn't get my foot on the brake fast enough and I coasted down the hill a lil bit. probably like 20 ft. not much at all. I drove over to where I set the scraper blade, dropped it, went to back up thats when I noticed the slop, and problem appeared.
Like I said I am new tractor owner.
With the clutch pushed in and tractor coasting [like downhill] the clutch plate is driven by the trans if youre in gear. If its a low gear the plate will spin very fast and can disintegrate. This can happen instantly with too much speed in a low gear.
larry
Glad for the remission. ... May be false. Sudden appearance of play is a sign of the clutch getting thicker - something that a disintegrating clutch could do by the lining moving. A test you could try is to get going med slo but wide open down a mild incline. Then let off the throttle, push in the clutch for a second or so to let the engine slo, then let the clutch out. This will load the clutch opposite to the normal direction and tend to move the lining [if indeed displaced] back toward its normal position. If it moves things will change and youll notice. If it doesnt youre still in the dim on the cause. :confused3:OK, here's an update. I finally got my new hydro coupler. removed front end loader. Heres whats boggles my mind. Now everything seems to be working normally.other than a more than normal pedal movement. I mean I can let the clutch pedal out and when it catches it will almost pull the front end off the ground. Crazy. I removed the inspection plug. about 1 1/4 size hole, from what I can see nothing appears to be broke. This tractor has 2 PTO outputs. one for the rear, and one for a belly mower, that isn't attached. Can having either one of these engaged cause the tractor to feel like its got a bad clutch. In my mind it shouldn't. I'm going to play around with the adjustment some now that its easier to get to with loader off. I check back in on how that whats out for me.
I'm with you on this one, doesn't make since for a mechanical part to all of sudden to quit working properly and then start working. May since it is working, I'll do some more moving of stuff unitl it quits again. LOL. Hate for my tractor to be out of commission. You realize how much you use it when its broke and cant use it..Glad for the remission. ... May be false. Sudden appearance of play is a sign of the clutch getting thicker - something that a disintegrating clutch could do by the lining moving. A test you could try is to get going med slo but wide open down a mild incline. Then let off the throttle, push in the clutch for a second or so to let the engine slo, then let the clutch out. This will load the clutch opposite to the normal direction and tend to move the lining [if indeed displaced] back toward its normal position. If it moves things will change and youll notice. If it doesnt youre still in the dim on the cause. :confused3:
larry
