Buying Advice About to buy, advice and sanity check requested (includes prices)
   / About to buy, advice and sanity check requested (includes prices)
A picture without any explanation doesn't make any point in many cases, and certainly not in this case.
The OP is new to tractors, how can you assume he knows that there are tractors using those mowers even though they aren't the same width? Without some sort of explanation, it doesn't help him at all, and he's left to guess.
Not to fuel this fire, but I was indeed confused by the pictures posted. I first thought that they must be the wrong pictures or otherwise I was missing something. I am new to tractors, so a little explanation and nudge in the right direction goes a long way.
   / About to buy, advice and sanity check requested (includes prices) #43
And I apologize for that.
But you can use up to a 6 foot brush hog as long as you don't let the pasture get too overgrown. So if you run across a good deal on one, don't be afraid purchase it.
Sounds good. Speaking of good deals, is there a particular time of year that better deals are to be had? I plan to check some local auctions and would assume that fall would be a good time to look, but maybe people sell more in the spring when demand is higher?
   / About to buy, advice and sanity check requested (includes prices) #45
Depends on the implement you are looking for as to timing. Best rule of thumb is 'off season'.
Unless it's an estate sale. Then try to attend estate sales in inclement weather........as bad weather keeps most folks home and prices are generally lower.
It appears the Kioti extended the free loader promo through August, which gives me more time to consider. However, I am pretty convinced that Kioti and the CK35 are the way to go. The extension may give me a little more negotiating power with the dealer, however. I am going to re-read through all the responses tonight and compile the details into what I'll request. But for now I must tend to the chickens and some garden chores.
   / About to buy, advice and sanity check requested (includes prices) #47
Let us know your decision............inquiring minds want to know :)
   / About to buy, advice and sanity check requested (includes prices) #48
dkair,
I see you have not mentioned the type of soil or terrain that you are farming in. If your in Stearns county (CN Minn) your soil composition can vary from sandy loam to black gumbo which have a bearing on the HP you need to operate certain implements for tillage. If any ground engaging implements are in the future (disc as you mentioned) you'll need the HP especially if it's a pull type. I know the soil & land there cause I was raised on it.
idaho2
   / About to buy, advice and sanity check requested (includes prices) #49
I stumbled onto the local farm auction scene, and scored really good deals at the first big auction if the year.....well before any real farming was being done. Your local TSC, or hardware store will likely have fliers. Still, Craigslist usually has some decent deals if you pay attention, and other places are worth keeping in mind. I bought a solid 5' brush cutter, and 72" rake for $500 from an antique store in a farming community. The cutter had a questionable gearbox, but that was a $150 fix for a factory new Omni replacement, so I'm still only around $450 into it.
dkair,
idaho2
Good question. Soil is clay loam. Our field and garden area are pretty flat, although there are some pretty steep hills around here. I'll be pulling some logs from steep areas, but most other work will be on fairly flat terrain.
Kubota SVL 97-2 (A53317)
Kubota SVL 97-2...
2023 BOBCAT T770 SKID STEER (A52709)
2023 BOBCAT T770...
2019 Land Rover Range Rover Sport AWD SUV (A55853)
2019 Land Rover...
2002 Chevrolet C8500 Flatbed - CAT 3126 Diesel - Eaton Fuller 8 plus 2 Transmission (A56435)
2002 Chevrolet...
2012 ADDCO S/A Towable Arrow Board (A55973)
2012 ADDCO S/A...
2016 Husqarvana YTA22V46 46in Riding Mower (A56859)
2016 Husqarvana...
