Down pressure on loader on L4400
/ Down pressure on loader on L4400 #1
kubota4me
USA
An orange one
I am going to be putting up some metal T posts and I was wondering if there is sufficient down pressure/force with the loader on the L4400 to drive them into the ground?
/ Down pressure on loader on L4400 #3
Depends on how hard your ground is.
+1 i know if the clay is wet my m8540 puts them in very easy, if its dry it will just make v shaped t-post
OP If there's not enough weight you can always fill the bucket with dirt. Or something heavy. If the ground is hard they can only be driven in with high force momentary blows
/ Down pressure on loader on L4400 #4
You have enough down to pick up the front of the tractor... so if the front is not heavy enough you can always put a half load of anything in the bucket to add some push..
My L4200 will push posts in easily..
/ Down pressure on loader on L4400 #5
You should have plenty of weight. If its really dry I throw four or five bundles of posts in the bucket. This is on an mx4700.
We've put in miles of fence this way. Goes very quick,with two people. Be careful!
2010 Gorman-Rupp T-Series T4A605-F3L Towable Trash Pump (A61567)
2010 Gorman-Rupp...
DIRT DOG SBX72-72" BOX BLADE W/TEETH (A62130)
DIRT DOG SBX72-72"...
2002 International 4300 Cab and Chassis Truck, VIN # 1HTMMAAP02H548742 (A61165)
2002 International...
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A63118)
2019 Krause...
2020 Peterbilt 567 Quint Dump (A62613)
2020 Peterbilt 567...
New/Unused Quick Attach Double Hay Spear (A61166)
New/Unused Quick...
