Sizing a Farmi logging winch to my CUT, is winch too small?
   / Sizing a Farmi logging winch to my CUT, is winch too small? #1
Piston
Elite Member
New England
Kubota L4610 Hitachi UH083LC
I'm looking at a Farmi JL290 for sale (used).
Does anyone know if this is too small for my 39 PTO hp? I get mixed feelings about what the website says, it claims 17-25 hp min/max but then says it fits both cat 1 and cat 2 three point hitches. I don't know of a Cat 2 tractor with 25 hp or less :D
I'd really like to buy a used logging winch or skidding grapple but they don't come up used too often. Should I try the 290 or hold out for a 351? Would a 501 be too big for me?
   / Sizing a Farmi logging winch to my CUT, is winch too small? #2
I use a similar winch on a 65 hp tractor, no problem. Farmi makes good winches so I would buy it.
   / Sizing a Farmi logging winch to my CUT, is winch too small? #3
If the price is right why not give it a try and limit your loads. Other than the larger cable (can be a down side when pulling my hand), weighting 100 pounds more and pulling 1000 pound larger loads they look quite similar. Instead of working it at 540 RPM (full engine power) run the engine at more like 1000-1200 RPM and increase the speed of the winch so your tractor is making a lot less than 39 HP. You might wait 10 days or 10 years to find a used 351.
What kinds of loads do you plan to be pulling?
   / Sizing a Farmi logging winch to my CUT, is winch too small? #4
Piston the JL290 is the exact same winch I have. Your tractor could handle the next size larger winch but I see no problem putting the JL 290 on your tractor either. It is a good rugged solid built winch. I doubt your L4610 will tear it up with the common sense you have. From what I have seen from your NH pictures it should go good in those woods if that is where you will use it.
Gordon,
I was really hoping you would respond to this, thank you for the advice, I've read a lot of your posts regarding the winch. Do you have any problems with the angle of the PTO shaft coming out of the tractor, and down to the winch? I will be using it on my land in NH and those are fairly small trees.
Gale, the price is hard to nail down, but I do think it is a good deal. We haven't officially come to an agreement yet but I've offered him some cash, and a 5' Woods rotary cutter as partial trade. He said he'd email me pictures but I haven't heard from him yet, so this may not work out, but I hope it does.
Tor,
What winch do you use?
All,
Do you know if this winch has only an upper pulley, and no lower pulley to winch from? Does this pose any sort of problem if it's the case?
I called Northeast Implements and asked about the differences in the 351 vs 290. He said they were very similar but the main difference is the 290 has the PTO shaft only 9" high, whereas the 351 has the PTO shaft 14" high. He said the 290 is really meant for smaller tractors but mainly because of the lower PTO shaft.
I also see that the Wallenstein has the FX65 which seems very similar, and is rated to 45 PTO hp.
The one advantage I see to the 290 is that since it's lighter, I will be able to lift more, and put less stress on my top link. I'm really concerned with the stresses on my toplink.
   / Sizing a Farmi logging winch to my CUT, is winch too small? #6
Tor said:
I use a Sandvik 3000.
And yes the 290 has only an upper pully, not a problem if you lower the blade to the ground when winching the heaviest logs.
   / Sizing a Farmi logging winch to my CUT, is winch too small? #7
Gordon,
It is a short shaft and makes quite an angle but no, I don't have any problems. Remember it only runs under load intermittantly and at low RPMs if you are sensible. I run my pto at about 300 rpm with the winch. Its not like a bush hog or mower working hard and running 540 all day long.
BTW the pto shaft center on my tractor is 22" off the ground.
Very helpful, thank you.
I think I will go for it. If for any reason there is a problem, I could always sell it and put the money towards a 351 or similar.
Do you ever winch whole trees? I'm wondering if I could winch and pull medium sized trees without too much trouble. Say, around 15-20" DBH?
Please excuse my ignorance, as I've never operated one of these before.......
I've "read" that winching isn't necessarily what puts the most stress on the top link, but rather, when you lift the load and tow it through hilly or rough terrain. Is this something I should worry about? I think I'm probably being a little overly cautious, which I am certainly guilty of doing in the past.
   / Sizing a Farmi logging winch to my CUT, is winch too small? #10
Piston, I have the 290 and use it on my MX 5100. I have had no issues. It will most certainly pull whole trees. I have yet to find a tree to stop it. I have had it snag and stop it but it should be a great winch for your tractor!
VOLVO EC460CL EXCAVATOR (A58214)
VOLVO EC460CL...
2009 Jeep Grand Cherokee 4WD SUV (A59231)
2009 Jeep Grand...
UNUSED X-STAR ACS LOADER BOOM LIFT (A52706)
UNUSED X-STAR ACS...
2014 Chevrolet Express 3500 Cargo Van (A55852)
2014 Chevrolet...
John Deere 2640 2WD Tractor with 146 Front Loader (A57024)
John Deere 2640...
1996 International Water Truck with a Caterpillar Engine (A56438)
1996 International...
