Turbocharging new L3940 Gutless Pig Tractor
Status
Not open for further replies.
   / Turbocharging new L3940 Gutless Pig Tractor #1
The Fred
hOOterville
Boost it and Lose!
Instead of bashing my new powerless L3940 HST Cab tractor I would like to turbo the thing.
I see the same engine is used in the Bobcat S-160 skid steer with a turbo.
Rather than tell me why I don't want to do this can you throw me some ideas? Very serious here.
Thanks, Fred
   / Turbocharging new L3940 Gutless Pig Tractor #2
Go order a replacement turbo for the skid steer online, you'll pay a little more since you don't have a core return. Next start hacking up the manifold, rerouteing the intake, welding, cussing and with a couple trips to the parts store you'll be in business.
   / Turbocharging new L3940 Gutless Pig Tractor #3
Will the fuel need to be turned up??
PLEASE do a thread on this for us, ok?
   / Turbocharging new L3940 Gutless Pig Tractor #4
I know a guy that turbo charged a L3940,I don't know any of the details but I know it can be done.
   / Turbocharging new L3940 Gutless Pig Tractor #5
Not an expert by any means but will the trans and axles take the additional power or will you end up chasing failures through the drive train?
   / Turbocharging new L3940 Gutless Pig Tractor #6
Good question, could be more than you bargained for
   / Turbocharging new L3940 Gutless Pig Tractor #7
I know somebody has got to ask....what are you doing where the tractor feels so underpowered?I had a L3130 HST that pulled a two bottow plow,pushed a six ft.snow plow ect.Traded for a L4240 mostly for the cab.I do most of my work with the L4240 in medium and toggle between high/low,this plus auto throttle I don't see how you can be underpowered.
   / Turbocharging new L3940 Gutless Pig Tractor #8
You will have to turn up the fuel pump unless the turbo is just set to break even. If you don't it will damage your engine.
   / Turbocharging new L3940 Gutless Pig Tractor #9
There was a person who added a turbo to their Kubota several years ago and posted pictures here some where.
That being said the "newer" 40 series Kubota's are "emissions certified" and I don't believe you can turn the pump up. Which would mean you would have to change the fuel pump. As others have said, will the rest of the tractor take additional power?
It's probably more you are losing power from the HST. I have a L3240 and do regret not trying harder to find a L3540 with the GST. While I have good PTO power, the unit HST isn't as good at putting power to the ground. I have to do everything slower than an equal HP gear shift unit. I have read that you can lose as much as 35% of your power through an HST. So as much as 1/3 of any gain could be lost. I don't know what % the Kubota HST uses.
   / Turbocharging new L3940 Gutless Pig Tractor #10
Very common for the pistons to be different, the rods, injectors, injector pump and or settings. If you just put the turbo on without changing everything else that is suppose to be changed for that particular engine, you have just taken an engine that has a 100% duty rating and lowered that duty rating. How much depends on the engine itself. Really not a good idea if you work your tractor hard any length of time.
Just saying what you don't want to hear, but it is what it is. Can you do it and everything be good, maybe, but then there is a better than average chance that it pops. :(
Good luck ;)
Status
2008 Ford F-250 4x4 Reading Service Truck with Liftgate (A48081)
2008 Ford F-250...
2005 FREIGHTLINER BUSINESS CLASS M2 DAY CAB (A48992)
2005 FREIGHTLINER...
2014 GMC Terrain SLE2 SUV (A48082)
2014 GMC Terrain...
2000 INTERNATIONAL 4700 (INOPERABLE) (A48992)
2000 INTERNATIONAL...
2007 AM General Corp M931A1 6x4 Truck Tractor (A48081)
2007 AM General...
2020 Utility Trailer Manufacturing, 53' Trailer (A47371)
2020 Utility...
