Tractors are not bulldozers.
   / Tractors are not bulldozers. #11
I have a cousin who goes through tractors like you wouldn't believe. He worked with rockets for twenty five years in the Air Force, fifteen with NASA, five more with Lockheed Martin, then two with one of their sub contractors. He could put a MIRV in Putin's bedroom, or a sat. on one of the moons of Saturn. Now that he is retired to the sticks and farming full time, he can't go three years without reducing a tractor to trash status. But his last buy was a small dozer. Maybe he will stop trying to clear land with his FEL. The first week he had his newest tractor, there were big dents in the bucket.
He does have a big garden here, and a smaller one at his place near the Cape.
Did you hit something with the tie rod, or did extreme traction from the front wheels pivot them toward the center, bending the rod?
Bruce
In this case it was all about traction. I had it in B1 so I had a good bit of torque and it decided to start hopping. I just didn't get on the clutch fast enough. If it wouldn't have hopped I probably would have been fine.
Im actually pretty good about not tearing them up. Then again I usually don't use them to clear land ;). My fleet includes a couple from the late 60's that still see regular use. Just got a little big for my britches this time. They cost to darn much to beat on regularly and I need them running and not busted so I can make my hay and feed my animals.
   / Tractors are not bulldozers. #14
You could have just straightened the original and got by til the new one came in. I honestly would have hooked a chain from the bucket to the tie rod and pulled the bend right out. They are mild steel.
   / Tractors are not bulldozers. #15
I know what you mean Mud. I don't farm anymore, just piddle with my garden. But I want my tractors to last as long as possible. We have a family who hunts on our land, and they like to use my 3930 to plant their food plots. More than once I have had to do minor repairs when I got it back. Just from them running over trees and brush they should have stayed off of. But they are good to do little odd jobs for Mamma while I'm out of pocket at work on the weekends. That is worth the occasional busted headlight and lost throttle linkage.
I thought of that option as well, but they way it was bent and hung behind the diff wouldn't make that option practical. Took about an hour to fab the new temp replacement one with a chunk of heavy wall square tubing that I had in the scrap pile and its working for now. New one should be in tuesday anyway so I will just replace it all then. Needed it for setting out hay for the animals and unloading trailers (hay season is in full swing for me right now).
Same here Larro, this tractor is an 02 and I gave 21k for it this winter, one of my others I have near 50k in. I hope to not have to buy another for a long, long time and as long as the pair of old 4020 JD's keep holding up I shouldn't have to. That being said I hope this and the TD5050 can last half as many years as the old green ones have!
   / Tractors are not bulldozers. #17
I bent the tie rod on my old B7500 by catching one wheel over a big chunk of concrete and reversed. It put a nice bend in it about like that one.. I took it off and beat it straight on a piece of railroad iron.. I used it several more years. Of course it is a much smaller tractor, and the tie rod was a lot smaller.
James K0UA
   / Tractors are not bulldozers. #18
James K0UA
Did you use a Bronson rock ?
Urban Dictionary: Bronson rock
   / Tractors are not bulldozers. #19
Just be careful until you can get the original one back on. When you replace the weakest link with something stronger then next weakest link will bend or break. It could be a lot more expensive to repair.
   / Tractors are not bulldozers. #20
Understood, that leaves the bucket option out. But a chain to a tree works well also:laughing:
2013 Chevrolet Silverado 3500HD 4x4 Crew Cab Flatbed Truck (A55973)
2013 Chevrolet...
2018 Honda Odyssey Van (A56859)
2018 Honda Odyssey...
2011 ROCKWOOD ULTRALITE 5TH WHEEL CAMPER (A52708)
2011 ROCKWOOD...
3PT SCOOP PAN (A52708)
LINCOLN ELECTRIC RANGER 225 GAS WELDER/GENERATOR (A54757)
LINCOLN ELECTRIC...
ARGO 6X6 FRONTIER ALL TERRAIN BUGGY (A52708)
ARGO 6X6 FRONTIER...
