Oil & Fuel BX2350 - the infamous second fuel filter
/ BX2350 - the infamous second fuel filter #1
c-and-a
Massachusetts
BX2350
From looking at the pics in the manual - best guess it is underneath the platform?
As I started my 50hr service - changed the fuel filter in the engine compartment, changed the engine oil/filter - without removing MMM...
front axle to follow....
I have to remove the MMM (and bagger) for tranny oil/filter - will I see the remaining fuel filter once the deck is removed...?
Any help is appreciated...
/ BX2350 - the infamous second fuel filter #2
Yes, you can't miss it. I think its the brass cylinder in this picture, though I've never changed mine. I knew this picture would come in handy!
SingleCoil - do I dare ask how you got this pic :)
Although it would make servicing the filter that much easier...
THX
/ BX2350 - the infamous second fuel filter #5
Silly me -- Been climbing underneath all this time to service that stuff. :cool:
Russell in Texas
/ BX2350 - the infamous second fuel filter #6
When life hands you lemons....:D
There is a thread on here titled "BX vs. 36" x 42" x 510 foot ditch" that describes how that one went over.
/ BX2350 - the infamous second fuel filter #7
Singlecoil, thats a mighty fine public announcement type pic of the underside of a BX, and I know the story. :D
As been said the 1st fuel filter (starting from the tank going forward) is under the skidplate. The brass device is the electric fuel pump.
The way Kubota did the filters is a filter "before" the fuel pump and another filter "after" the elec fuel filter and "before" the fuel injector pump in the engine compartment. This way the fuel is filtered before it gets to the electric fuel pump to protect it and the fuel is again filtered before it gets to the injector pump. This 2nd filter is insurance incase the electric fuel pump fails and it's debris doesn't get into and damage the fuel infector pump. It's actually a pretty thorough fuel system potection scheme.
The fuel injector pump is the most precise and expensive device to repair on a diesel engine (sans major internal repair) so keeping it clean and trouble free is paramount :D
/ BX2350 - the infamous second fuel filter #8
/ BX2350 - the infamous second fuel filter #9
Hello,
I bought a BX2350 '07 model about 4 months ago and love it! The problem I am having is it will run for about an hour and then it will cough, spit and puke for a bit and then take off. I figure it is the fuel filter but now I don't know which one. The filter that they gave me only has a screen on it and no pleats on the inside of the filter. They had the exact same filter but had the pleats on the inside which is the one I got. Which filter do I need to change. It has 267hrs on it now.
Thanks
/ BX2350 - the infamous second fuel filter #10
The first filter is the one most likely to plug up. I had that happen at 300 hrs. Plugged solid with black gunk. Never priced the Kubota ones but NAPA probably has them cheaper. I but the metal case ones (3032) as they are more resistant to damage. My fleet price is $4.08. Probably the cheapest replacement maint item. Like was said before that injector pump is big bucks. I change both every time I change oil. I moved the engine compartment one down under so it is now easy to change.
Ron
/ BX2350 - the infamous second fuel filter #11
Appears Kubota is copying JD. My new 1025 has the in line filter underneath the left side foot board. My 4010 only had a smaller-than-one-on-1025 on the engine inside a bowl. Only diesel problem I had was wax drop out one cold winter here. The wax droplets plugged the outlet from the tank. Didn't get to the filter.
/ BX2350 - the infamous second fuel filter #13
The filter with no paper pleats doesn't sound original part to me.I'm willing to bet thats the one under the tractor. I'd replace the filter under tractor first no matter what.if the one with out paper pleat is by engine,,I'd replace it with same filter with paper pleat.
/ BX2350 - the infamous second fuel filter #14
Great Thanks !
Yea NAPA is where I got the filters from. The one I have isn't metal, maybe I'll go back and see what they have because I need to get the other one.
Now is there a fuel shut off before I change these?
/ BX2350 - the infamous second fuel filter #15
I wish there was a shutoff. You will just need to clamp it of with vise grips. I was toying with the idea of taking the plastic lawn mower shutoff from store and put it in for next time.problem is I don't know if it will work exposed to diesel .
/ BX2350 - the infamous second fuel filter #16
Ok that was my next idea......Thanks!
/ BX2350 - the infamous second fuel filter #17
WOW that was easy,Thanks for the help guys. That sure made a world of difference, it idles and runs a lot smoother and there was a bunch of crap in those filters.
2017 International HX620 Quint Dump (A62613)
2017 International...
2019 GENIE S-40XC TELESCOPIC BOOM LIFT (A62129)
2019 GENIE S-40XC...
(INOP) 2017 FORD F550 XL SERVICE TRUCK (A62130)
(INOP) 2017 FORD...
2025 Swict 84in. Bucket Skid Steer Attachment (A61567)
2025 Swict 84in...
2014 Jeep Wrangler 4x4 (MPV), VIN # 1C4BJWDGXEL206125 (A61165)
2014 Jeep Wrangler...
2013 BMW 750i Sedan (A61569)
2013 BMW 750i...
