3-Point Hitch 3 pt hitch assembly
   / 3 pt hitch assembly #1
Kub39
Anyone have a picture if their 3 point hitch? Mine is still sitting in the box because there are no instructions. I'm not perfectly clear on the assembly, but if I at least had a picture I could put it together then I am sure. Bought my new BX25 about three months ago and haven't needed the hitch yet, but wanted to assemble it at least. Thanks for any help/advice.
   / 3 pt hitch assembly #2
I had the same problem last week so I stopped by the dealer and took some pics. Here they are. IMAG0631.jpgIMAG0635.jpg
Thanks. Pictures are worth a thousand words!
   / 3 pt hitch assembly #5
I installed mine finally this past weekend to make sure I knew how. Not sure why they used rings and cotter pins instead of clips in a couple of places. If you don't get instructions, pm me
Thanks. I'll probably tackle it this coming weekend.
What did you do with your operators manual? It is all explained in there. If your dealer did not give you yours, shame on them. Its on page 43.
Ron
Well I'll be...there it is on page 43. Guess I figured it wouldn't be in there since it was an option and doesn't come with the tractor. Kind of like the MMM had its own manual. My bad! Thanks for the info.
   / 3 pt hitch assembly #10
I'm going to stop by the dealer this weekend but anyone have any pointers for simple draw bars? Is a stabilizer important?
the manual shows 24in between mount pts. but an online web search doesn't show much out there... simple meaning holes for a couple lawn tractor type pull-behind (sweeper and aerator) that use a pin and for attaching a chain to pull stuff...
thanx
joe
2016 Ford Taurus AWD Sedan (A55853)
2016 Ford Taurus...
2004 MANAC 48FT CURTAIN SIDE SPREAD AXLE TRAILER (A57880)
2004 MANAC 48FT...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55853)
2006 iDrive...
2012 UNVERFERTH 13-INCH REAR SPACERS FOR 10 BOLT HUB (A55315)
2012 UNVERFERTH...
202477 (A54757)
202477 (A54757)
2013 John Deere 85G Midi Excavator (A55851)
2013 John Deere...
