Lightning Bolt Warning Light Problem - Redux
/ Lightning Bolt Warning Light Problem - Redux #1
frankmako
North Georgia
Ford 4610, Ford 3910 and YM1601D
The lightning bolt warning light on my YM1601D came on today about one hour into a four hour bush hog job. The tractor was running around 2,300 rpms on level ground. The light flashes on and off. Sometime the light is bright, mostly it is dim flashes. It has done this before several times in the past when I use the tractor to bush hog. This problem first started in 2009. Back then I changed out the belt trying to fix the problem, but it did not do any good. So today I turned on the tractor lights and the warning light stopped. So I cut the field today with the lights on today. If I drop the rpms below 1,500 rpms the light will stop. It only does it when I use the tractor cutting at high rpms. All other times/work it never comes on. Must be something about low rpms that keeps the light out. Over the past several years I have changed out the belt and the voltage regulator. The charging system is working as it should so the generator is good. Either I got a lose wire or something bad is going on. Could this be an over-charge condition? Could this be belt slipping at high rpms. What checks do I need to do to run down this problem?
/ Lightning Bolt Warning Light Problem - Redux #2
it could be a wornig light to tell you that you are over revving it ..try cutting at 2000 and a lower gear or just go slower..:eek:
/ Lightning Bolt Warning Light Problem - Redux #3
I had exact issue on a ym2001..its most likely a loose wire..I think up near battery. On mine I snipped the connectors and just twisted the wires together with electrical tape..I may have a thread on here about it..would be years ago..
/ Lightning Bolt Warning Light Problem - Redux #4
If you don't find any external problems. Take the alt. off and have it checked at an alt. repair shop
/ Lightning Bolt Warning Light Problem - Redux #5
When it is doing that reach down under the dash to the fuse box and rotate the fuses and watch your light.
/ Lightning Bolt Warning Light Problem - Redux #6
The connector on the back of my alt is kind of slopply the stud seems loose and every now n then my charge light. Flashes. U can affect I. By wiggling the wire on it. Will do It then stop for months then do it part of a day and stop. I don't worry as 95% off the time I dint get it?
it looks like the fan belt that I put on two years ago is the problem. it is slipping. I got it at the local auto store. so I know it is not the correct size. the adjustment is at the end so I don't have any more to go. so does anyone know the correct size v-belt that will fit. I know I can order one from hoye, but I need to have this done by the first of the week.
/ Lightning Bolt Warning Light Problem - Redux #8
I do not warranty this but this is what I think. Goodyear 17341 or metric number 13av0865
check the fan belt and it was had just a little play in it. fixed the problems and now the light is on all the time. out comes the volt meter to check the alternator and the readings at 1,500 rpm i get 20 vac and at 2,000 rpm i get 24.5 vac. so it looks like it is good. go to the battery and i get 12.35 volts. so nothing going to the battery from the regulator. yesterday the battery was getting over 13 plus volts and the light was off. go the voltage regulator and can not get anything coming out. or i must not be checking the correct wires. i have the new vr-522 regulator on. i put it on in 2008. what wires to i need to check to see what is coming out of the regulator?
/ Lightning Bolt Warning Light Problem - Redux #10
Touch the black lead on your volt meter to ground. The red lead on the voltmeter to red or white coming out of the regulator should show 13+dcv.
called hoye's today. they told me to check the fuse. they said the replacement regulator that i put in several years ago should have not failed. the fuse is not getting good connection. now i got to find the fuse panel. i think it is some where under the dash behind the panel in front of the gear shift.
/ Lightning Bolt Warning Light Problem - Redux #12
I mentioned that in post #5. Your fuse panel is right under the dash, little to the left of center.
fuses are good. battery is good. took it out and had it checked, showed 12.65 volts. that is good with me running the tractor and 30 plus starts trying to run this problems down. load test was also good on battery. checked all wiring, all were good. but i still get 12.4 reading on the red wire, yellow wire and tan wire coming from the vr-522 six wire voltage regulator (vr). on the starter i have a wire from the battery and a red/white wire and a red wire going to the same post. i have read you take the red wire off to check the vr. but the red/white wire and the red wire are made on the same spade. looks like a factory job. when i take the red/white/red wires off the tractor and put the battery wire back on the starter the tractor will not turn over/start. i have a wire that goes to the top of the start at the solenoid that has no power to it when running. t i can not see what color it is, except yanmar green. so it looks like the second vr has failed or i am missing something. where do i look now before i buy a third vr.
/ Lightning Bolt Warning Light Problem - Redux #14
When I bought my YM2000 I was having the same exact problem. It has both Regulator's also Old style and New. Drove me nuts. Ended up loose/bad were it connects to the back of the Fuse Panel. After finding it and curious I hooked the Old Reg. back up and it works also.
/ Lightning Bolt Warning Light Problem - Redux #15
I don't want to be a naysayer but I have replaced my vr522 regulator twice on my 2002d. In my earlier post I stated you should get 13+dc volts out of the red and white wires coming out of your regulator. I think instead of white the wire is probably yellow. In any event if you stick your red test probe down in that plug to touch the wires it is the red one and the one right next to it. Naturally you would have your black test probe touching ground. Just to clarify I am posting a picture. I remove myself from all liability if you buy a new one and it doesn't solve your problem. :D I just know from personal experience these so called "no problem" regulators can go bad. I also know mine puts out 13+ volts on those two wires. :thumbsup:
/ Lightning Bolt Warning Light Problem - Redux #16
Yep! it was the the yellow wire 10 amp. connection on the fuse panel. And sure enough CRS. so I had to go look. Were does it go? The Voltage Reg. :) I have a 520 Reg. yours should be a 522 but it looks to be wired the same looking at my YM2000 Dia.
/ Lightning Bolt Warning Light Problem - Redux #17
Yep a "no fail" part can fail. After all its just a part, they wear out.
I have replaced many "no/low failure" parts on all kinds of things in my day.
Exhaust manifold in a southern truck at 20 years old, stator in one of my outboards, lets see on and on... THose are just a few that come to my mind. There are plenty of others im sure.
Oh last work truck i had, new power steering pump at 30 000 miles, catalytic converters at like 60 000miles......
the red, yellow, and tan wires read the same, 12.4 volts. so it looks like i will have to replace the vr for the third time.
Got in a new voltage regulator and on it went. Problem gone. It looks like the voltage regulator was the problem all along. But i did all the checks and run down all the wires to make sure I did not have any other problems. So now the tractor is on it's third voltage regulator. I just hope this will be the last one I will have to do.
1996 Vermeer V-3550 Ride-On Trencher (A61572)
1996 Vermeer...
2015 Ford F550 4x4 with 37' Bucket (A62613)
2015 Ford F550 4x4...
2019 PETERBILT PB337 LUBE TRUCK (A63276)
2019 PETERBILT...
Adams 5 Ton Fertilizer Spreader (A63688)
Adams 5 Ton...
For Sale L4479 Snowblower and Subframe
For Sale L4479...
2021 Scout 210 Dorado 21ft Boat w 18ft S/A Boat Trailer (A61574)
2021 Scout 210...
