Physical Size of 5101E, 5115M vs 6115M and 6115R
   / Physical Size of 5101E, 5115M vs 6115M and 6115R #1
Thowle
Kentucky
John Deere 4066R Cab w/ H180 and 4-in-1 Bucket
I was looking on the Deere site, among others -- but can't find good specifications.
Does anyone know what the physical size difference is between the 5E, 5M, 6M, and 6R tractors?
I did find that the wheelbase difference from a 5M to 6R is about 12 inches wider.
What I'm really interested in is the height.
I'm familiar with a 5101E; but never been around any of the others -- so if someone can give reference based on the 5101E to compare size, and cab specifics -- that would be great!
   / Physical Size of 5101E, 5115M vs 6115M and 6115R #2
Here's a little for you, from Deere's web site.
Length (no weights to end of 3pt arms) 6115M 176.6" 6115R 178.8"
Height with cab 6115M Min 106.6" Max 111.1" 6115R Min 105.2" Max 113.7"
They did not explain the reason for a min & max height, I think they must have a suspension system for the cab :confused3:
   / Physical Size of 5101E, 5115M vs 6115M and 6115R #3
I would think the height difference has to do with tire choices?
   / Physical Size of 5101E, 5115M vs 6115M and 6115R #4
Yes, and the cab suspension / Triple Link Suspension.
   / Physical Size of 5101E, 5115M vs 6115M and 6115R #6
Did you ever find who stole your tractor?
Yeah, found it. stuck into ditch. Recovered it today. I think its hydrolocked, posting pictures later. Don't know who did it though which sucks..
   / Physical Size of 5101E, 5115M vs 6115M and 6115R #7
I know that when you get to the 5115M series and above the tractors have an actual frame in them, where the 5101E uses the engine block for the frame. I am not sure how much taller they would be. I think they use the same cab. Tires would make a big difference as well.
PAIR OF 29 FT PIPE RACKS (A50854)
PAIR OF 29 FT PIPE...
2002 FREIGHTLINER FL70 DUMP TRUCK (A51406)
2002 FREIGHTLINER...
SERVICE BODY BED W/CRANE (A50854)
SERVICE BODY BED...
2018 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A51222)
2018 FREIGHTLINER...
2013 CHEVROLET SILVERADO 2500HD (A50854)
2013 CHEVROLET...
REYNOLDS 100 - 8 YARD PULL TYPE SCRAPER PAN WITH DRAWBAR (A51039)
REYNOLDS 100 - 8...
