My new KB2485 Hoe has no power
   / My new KB2485 Hoe has no power #21
Would I be correct in assuming this kit would also improve the function of my Woods Backhoe?
   / My new KB2485 Hoe has no power #22
Better flow and better cooling should result in better performance of any hoe attached in this manner.
YRMV.
   / My new KB2485 Hoe has no power #23
The Woods doesn't use both rear remotes, it only gets the feed from there, their return kit is plumbed into the valve bank up my the loader control
   / My new KB2485 Hoe has no power #24
The Kioti kit allows for the outflow from one rear remote. The return goes into the trans fill/vent port. the vent gets moved to the other side of the trans and is a smaller fitting and rubber vent 'hose'. All you'd have to do is adapt your return line to connect to the trans fill post with the appropriate sized QD. Male into the fill port and female out, to male off your hydraulic line.
   / My new KB2485 Hoe has no power #25
Does anyone have the part number for the conversion kit so I can look them up?
   / My new KB2485 Hoe has no power #27
Ask your dealer, the kit # is not in my parts book
   / My new KB2485 Hoe has no power #28
Both of my Kioti's came with it from my dealer. It might have been ordered by the dealer for the tractors he sells. It consists of a new smaller vent tube and fitting that attaches to a port on the left side upper back of the trans, and an adapter to replace the big red fill plug/vent that screws into the fill port on the right backside of the tractor. The right side adapter has a female QD, which plugs into the backhoe's male QD coming off the hoe's return line.
Instead of worrying about looking this stuff up why not ask your selling dealer(s) about how to go about getting the kit?!:confused2:
It's a couple of pieces, and can't cost much, BUT it does provide real benefit.
   / My new KB2485 Hoe has no power #29
Just got mine from my dealer for free. I'll try and get it hooked up this week and post what I discover.
   / My new KB2485 Hoe has no power #30
So did they give you any part #'s, or a kit name for reference for others here?
Could you post a pic of the kit parts for those who want a kit, to see what it consists of?
1992 Ford L900 Cab Chassis with Low Milage Cummins (A55315)
1992 Ford L900 Cab...
2010 MULTIQUIP 25KW GENERATOR (A55745)
2010 MULTIQUIP...
Toro Groundsmaster 3500-D Rotary Mower (A56857)
Toro Groundsmaster...
2015 Ford Fusion Hybrid Sedan (A56859)
2015 Ford Fusion...
1996 Sunflower 1543-38 Folding Disk (A56435)
1996 Sunflower...
1996 International Water Truck with a Caterpillar Engine (A55315)
1996 International...
