Speedometer don't work on a 3320 john deere tractor
   / Speedometer don't work on a 3320 john deere tractor #1
Gail Rodda
Solomon Kansas
3320 johndeere
How do I repair the speedometer on my 3320 tractor. It just goes up 4or 5 tenths. Gail Rodda gdrodda@yahoo.com
   / Speedometer don't work on a 3320 john deere tractor #2
If you want to do these repairs, you really ought to invest in a service manual.
   / Speedometer don't work on a 3320 john deere tractor #3
Were it a mechanical speedometer you'd probably have a cable issue. Since it's digital there has to be a sender with output to the gauge. Hit the sending unit with a Crescent Wrench (not too hard now) and see if that helps. I fixed my radio that way one time.....but the wise words out of Vermont are probably better advice and I don't mean point a gun at it to see if it's emotionally mature........
I have a service manuel. It don't eaven show where the sendor is.
   / Speedometer don't work on a 3320 john deere tractor #5
Must hook up to the trans somewhere.
   / Speedometer don't work on a 3320 john deere tractor #6
:laughing: And if that won't work, try the heel of your boot and call it a kawasaki. :shocked:
   / Speedometer don't work on a 3320 john deere tractor #7
You could call a dealer and I'm sure they would give you some advice on where it's located and perhaps how to test it. I guess there's a good use for a speedo on a tractor but it just doesn't occur to me although I guess spraying or some harvest implements might require speed over the ground information.
Good luck with it.
2007 KENWORTH T800 BOBTAIL KILL TRUCK (A58214)
2007 KENWORTH T800...
2214 (A58376)
2214 (A58376)
2008 John Deere 310SJ Backhoe (A59213)
2008 John Deere...
2012 DOOSAN G25 GENERATOR (A58214)
2012 DOOSAN G25...
New/Unused Agrotk Wood Splitter (A57453)
New/Unused Agrotk...
KUBOTA SVL75 ENCLOSED CAB (A52706)
KUBOTA SVL75...
