overrunning coupler
/ overrunning coupler #2
how do I remove an overrunning coupler from a ford 8n?
if i remember correctly, theres a drive pin run thru it. This prevent the coupler/clutch from coming off of the spindle.
/ overrunning coupler #3
yep, take out the grease fittings on each side and turn it till the holes line up with the roll pin, then drive it out with a punch. Your PTO shaft on the tractor is probably 1 1/8" so if you plan to use it you will need an adapter, unless it has been upgraded.
2017 CATERPILLAR 950GC WHEEL LOADER (A64279)
2017 CATERPILLAR...
2014 Kenworth T370 S/A 14ft. Cab and Chassis Truck (A64194)
2014 Kenworth T370...
2015 Ford F-550 4x4 Liftmoore 2550 5,000lb. Crane Service Truck (A64556)
2015 Ford F-550...
New/Unused AGROTK YC-32G Horizontal Band Sawmill (A65583)
New/Unused AGROTK...
New/Unused 3-in-1 Quick Attach Frame (A65583)
New/Unused 3-in-1...
(4) Brawler 40 x 9 x 13 Skidsteer Tires (A66408)
(4) Brawler 40 x 9...
