B2620 vs BX2370
/ B2620 vs BX2370 #21
Good to hear the new tractor is working out as you had hoped do far. Can't help much with the mulching blades, did you ask your dealer?
/ B2620 vs BX2370 #22
The 2620 has arrived. My lawn had not been cut for 1.5 weeks and it was wet, so there was quite a few clippings, but no clumps. The cut quality is nice, but clippings seems to be the only issue. I will have to repost my thoughts after another week or two, b/c I did cut the grass from probably 4.5inches down to 3. The engine runs smooth and has plenty of HP. I mowed the stripe style back and forth, making 3pt turns, and did not damage the grass with the tires at all.
Overall is makes mowing a breeze and has a good cut. I will probably look into the mulching blades. Anywhere to order mulching blades that dont need to be drilled out? How did you guys drill the converted bx blades?
Oregon has 3in1 blades for the 60 deck. No drilling needed. I got some a 1 1/2 ago. I like them better than the stock blades. When I got them, I posted pictures of them and the parts number
/ B2620 vs BX2370
Those 3in1 blades are for the BX series. The mower on the B series has a large blade bolt and needs the blade to have a larger hole. Thanks.
/ B2620 vs BX2370
The Kubota blade part number for the RCK60-29B is K5645-34340
A Oregan Gator blade replacement is the G3 96-363.
213135 (A64276)
213135 (A64276)
2003 (INOPERABLE) CHEVROLET C7500 (A67714)
2003 (INOPERABLE)...
WeeDoo (A66738)
WeeDoo (A66738)
2437 (A65640)
2437 (A65640)
2019 KENWORTH T880 TRI-DRIVE HYDROVAC TRK (A67714)
2019 KENWORTH T880...
FUEL TANK (A68842)
FUEL TANK (A68842)
