Well I did it... 50 degrees on the tiltometer
   / Well I did it... 50 degrees on the tiltometer #1
woodlandfarms
Super Member
Los Angeles / SW Washington
PowerTrac 1850, Kubota RTV x900
I have this slope alongside my driveway. Dozer cut and steep as all heck. Generally I just mow by lifting the mower and pushing from the road into the hillside. Today I got a wild hair and figured worse that would happen is that I would tip, more than likely just get stuck. It is only maybe 8 feet high, and the road is at the base.
Anyway, PT was more than stable on its side. Never once felt like tipping over. I have 30 degree slopes all over, but this is the steepest area I mow. I am not set up for severe slopes. My tire pressure is around 10 to 12 lbs and I have my chains on. I was really driving more at a 45, kinda jackknifed. It was very slippery, constantly working the to keep moving forward and not slide onto the road. In the end I slid into the "ditch" that runs along the road, That is where I noted the inclinometer and realized I was stuck. Getting out was nerve wracking. The wide tires made what would be obvious easy extraction impossible. i ended up using the mower to lift me out, prying myself up and out. The issue was on tire would get off the ground and once that happens it all goes south.
   / Well I did it... 50 degrees on the tiltometer #2
I declare you King of All Slopes!
Now go change your shorts. :laughing:
   / Well I did it... 50 degrees on the tiltometer #4
When Ponytug was going to buy a PT, he asked about slope capabilities. I put an inclinometer on mine and discovered I was "comfortable" at a 20 degree sidehill and wouldn't want to try anything over 25, but that's a difference between dual wheels and not.
I'm with MR... you are the SLOPE KING!
Phil
   / Well I did it... 50 degrees on the tiltometer #5
No pictures.....It didnt happen :D
   / Well I did it... 50 degrees on the tiltometer #6
I do 20, so I would guess 25 would be my comfort limit.
   / Well I did it... 50 degrees on the tiltometer #7
I need to try a Power Trac, especially since they are built just a hour from here.
..And yeah, how about a picture of that slope?
   / Well I did it... 50 degrees on the tiltometer #8
   / Well I did it... 50 degrees on the tiltometer #9
Funky looking grass that he has in his lawn... :D
1998 Wirtgen WR2500 Soil Stabilizer/Cold Asphalt Recycler (A55787)
1998 Wirtgen...
2025 Wolverine SBM-12-72W 72in Sickie Bar Mower Skid Steer Attachment (A55787)
2025 Wolverine...
2012 Chevrolet Silverado 2500HD Enclosed Service Truck (A53422)
2012 Chevrolet...
2015 Haulotte 5533A (A53314)
2015 Haulotte...
JOHN DEERE 6135RW401 MOTOR (A51247)
JOHN DEERE...
P.T Canal Pump (A53316)
P.T Canal Pump...
