Weed Killer is OK ?
/ Weed Killer is OK ? #1
xxMaterskixx
Ontario, Brampton
John Deere 1026 R and John Deere 5115M
Hi
The question is that ok i spray weed killer at my crop same time? If i spray my grass or potatoe the plante will die? I should spray Weed killer before that i will plante the seed? For example i have a potatoes crop right now... It is ok i spray weed killer at my potatoes crop at same time but the question is the potatoes plante will die ?
Thanks
/ Weed Killer is OK ? #2
"Weed killer" is a very broad term, and doesn't tell anyone which chemical you want to use.
/ Weed Killer is OK ? #3
Agreed. You need to check the labels of the herbicides that you are considering. The labels give info on residual effects, time required before planting various crops, etc.
Steve
/ Weed Killer is OK ? #4
Should be called vegetable killer. Don't know if I would want to eat anything from that plot. Good luck
i Agreed both of you but last question is can i use insect, fertilizer and weed killer at same time that is ok? but i understanding the weed killer show the lables that what i have to do but i agreed. i am tell you another story is the insect, ferlitlzer and weed killer at same time that would be ok?
Yes but it will work ? Or I should not ? But a real farmer they do that or not?
thanks
/ Weed Killer is OK ? #8
You need to list the specific chemicals in any of these products for anyone to give you any sort of idea if they're safe to be used together on vegetable garden. I would never use a "weed killer" or "insecticide" without first studying the exact chemical makeup of the specific products and finding out what is in them. Real farmers research such things.
ok i understanding dont mix with chemicals but i have do one time each ? I should spray weed killer at other time like in fall or spring right ? Other question is i should spray before i planting or i can spray now if there are planting at crops ?
/ Weed Killer is OK ? #11
Hi
Thanks
You should visit your local OMAFRA office and pick up a copy of the "Guide to Weed Control" and "Grower Pesticide Safety Course Manual". These guides explain which pesticides and herbicides can be applied to which crops, how many applications per season and when they are permitted to be applied in Ontario. You must be licensed in Ontario to purchase pesticides and herbicides.
Thank You!! Im from Ontario as well !! I go to OMAFRA office ans ask them i need copy of "Guide to Weed Control" and "Grower Pesticide Safety Course Manual" after that they will give me a licensed ? or i have to take exam ? how it work ? "Guide to Weed Control" and "Grower Pesticide Safety Course Manual" is including the pesticides and herbicides ? Send Me Messages or reply me back Thanks!
/ Weed Killer is OK ? #13
You have to take a one day course and test. Test is very easy and open book. The test ensures that you can actually read, understand and follow the instructions correctly on product labels. If you can read a product label and follow simple math ratios you will pass the test. See links for all details.
Ontario Pesticide Training - Ontario Pesticide Training and Certification
About the GPSC exam - Ontario Pesticide Education Program (en)
I just call the office a hr ago but you are right it is easy and the office say I need to read the book or download from online but they say you need just Grower Pesticide Safety Course Manual just it after that if I am ready then, I can write a exam, if I past I will get my farmer licence right?
but the book is about 400 page! That is a lot !!! But why Ontario farmer need licence ??
Heavy Duty Steel Baskets (A65579)
Heavy Duty Steel...
CONEX BOX (A65643)
CONEX BOX (A65643)
2018 CAT 259D Skid Steer (A62613)
2018 CAT 259D Skid...
WESTINGHOUSE PORTABLE ARC WELDER (A64276)
WESTINGHOUSE...
New 50Pc Equipment Key Set (A65579)
New 50Pc Equipment...
(4) Ratchet Straps (A65583)
(4) Ratchet Straps...
