So, maybe you're wondering what would stop a discbine?
   / So, maybe you're wondering what would stop a discbine? #11
Here's a question while on this topic what happens when a Discbine hits a mole hill? That's my biggest worry in my field.
There are lots of mole(Gopher) mounds down here in Texas in the sandy hay fields. My disc cutter goes right through/over them. Makes a "Whump" sound,blows out a dust cloud and keeps on cutting grass.
In my experience, whenever knives get into the dirt, be it mole/gopher hill, edge/berm, or just feild topography, there's an immediate danger of rocks being thrown forward to the operator. I found out *after* buying my discbine that a cab tractor is recommended. And you'll read lots of stories of discbines taking out the rear windows of cab tractors. So make sure you keep the front curtain in good shape. I've only had that happen to me in a very dangerous manner once - I was coming over a slightly elevated road way so the discbine was in the raised position and the tractor was about level with the cutter bar. When the moving knives hit the edge of that gravel road all heII broke loose, the tractor was pelted with a bunch of small rocks at speeds of probably well over 100 mph - it was like someone was shooting at me. I was lucky and took no direct hits, and learned an important lesson!
Longer term, cutting through dirt is obviously not good for the knives (but they're easily replaceable), and probably not good for the bearings. Running rocks through the flails or rollers can't be good for them either.
   / So, maybe you're wondering what would stop a discbine? #13
Same thing here, but the mounds are fire ants.
Sent from my iPhone using TractorByNet
   / So, maybe you're wondering what would stop a discbine? #14
Never fear there are plenty of fire ant mounds where I live to go along with the Gopher mounds
   / So, maybe you're wondering what would stop a discbine? #15
I don't think I'd trade all the mosquito's, black flies, white socks, and no-see'ums we've got up here for your fire ants... nah; rather be itchin' than burnin'! :laughing:
AKfish
   / So, maybe you're wondering what would stop a discbine? #16
Hey we got other pest too, yellow flies, mosquitos, and no see ums also known as sand knats. When you get bit by fire ants toy want forget, they don't bite until about 15 to 20 gets on you and then BAM.
   / So, maybe you're wondering what would stop a discbine? #17
The previous owner of my disc mower (bar only, not conditioner) said that it will cut right through metal fence posts.
When I was cleaning it, I also found coils of barbed wire under two of the discs, which obviously had thrown it off balance enough to make a hole leaking oil in the cutter bar.
Ouch! I hope you caught it before all the oil leaked out? Still sounds like you're going to want to drain, disassemble, clean and repair that cutter bar? Could be bits and pieces of anything in there...
   / So, maybe you're wondering what would stop a discbine? #19
On some of the Deere disc mowers they use a pipe nipple for a fill tube. The threads cut into the tube tend to allow the end of the tube screwed into the cutter bar to crack. Which we didn't catch in time the 1st time. So the tube broke off flush with the cutter bar. Yet it fits in a cutout in the frame so even when broken right off still sits up straight.
Needless to say once the pipe breaks off it only takes a short time to blow the oil out of the cutter bar. Once that happens in a very short time the cutter bar stops turning due to parts of it set up solid.
   / So, maybe you're wondering what would stop a discbine? #20
One year neighbor had a sometimer and hit a 1500 LB rock he knew was there full tilt dead center with his next to new discbine...5 sec in dreamland ,..and total distruction.
There were not that many good parts to be salvaged from it.
15 years ago I scooped up a discarded/forgotten powerpole lengtwise top first in my haybine on the first round in a cropshare hay field 4 hr drive from home, it went in between the cutterbar and the auger and was 10' trough the crimper before it jammed solid,..slam bam thank you mam.
I went home power pole and all and never went back.
Took me a full day to get the pole out and the damage repaired.
2015 Dodge Charger Sedan (A55853)
2015 Dodge Charger...
DYNAPAC CA30D SMOOTH DRUM ROLLER (A52707)
DYNAPAC CA30D...
2015 Ford F-350 4x4 Ext. Cab Liberator 3,200LB 1.5 Ton Crane Mechanics Truck (A55973)
2015 Ford F-350...
2008 Isuzu NPR-HD Landscape Dump Truck (A53422)
2008 Isuzu NPR-HD...
2022 MACK GRANITE TANDEM AXLE DUMP TRUCK (A54607)
2022 MACK GRANITE...
HAMM HD14i SMOOTH DBL DRUM ROLLER (A52707)
HAMM HD14i SMOOTH...
