Howdy - "New" L2850DT owner
/ Howdy - "New" L2850DT owner #1
JTeague
Rock Spring, GA
Kubot L2850DT
Hello all.
I just bought a 1986 L2850DT Kubota ... only 595hrs! Runs well and was evidently taken care of -- paint isn't faded and everything works smooth. I bought it with a L&S Line 5' bush hog. I want to get a box scrape and boom pole to start with ... looking mostly at craigslist ... and will go from there. (I've read about hydraulic top links in a couple of places here... and it seems that will be on my list pretty soon too) KubotaL2850.jpg.
Looks like a great forum. Good to be part of it.
Y'all have fun.
JT
/ Howdy - "New" L2850DT owner #3
:welcome: to TBN from Ohio
/ Howdy - "New" L2850DT owner #4
Welcome to TractorByNet!
I moved your thread to the Kubota Owning & Operating forum. :)
/ Howdy - "New" L2850DT owner #5
Welcome toTractorByNet and greetings from Tennessee.
/ Howdy - "New" L2850DT owner #6
I bought an older 1990 l2600 dt last year. Very similar to yours , 26 hp. Would you believe only 210 hours, AND garage kept. Came with a 5' bush hog and woods fel. I love these older tractors. Enjoy!
I was hoping to find one with a FEL ... but this turned up and was a good buy ... so I'll either add FEL later ... or maybe have 2 tractors later :)
Anyone have thoughts on how difficult it is to add a FEL to an older tractor like this? (any special considerations ... modifications needed ... etc?)
Thanks
JT
... greetings from Tennessee.
My tractor lived in TN before I brought it down to GA! Bought it from a fellow in Strawberry Plains (just above Knoxville). I guess Kubota is popular for the color if no other reason in that neck of the woods !
I thought 595 hrs was low for my 1986 L2850... yours barely had the rings and valves seated !
/ Howdy - "New" L2850DT owner #10
WE bought a L2850 from a rental place and have used it well for many years. A great tractor. 1/2 of our acreage is in 100 flood plain so lots of use of the 4wd. Just replaced it with a L3600 tonight.
/ Howdy - "New" L2850DT owner #11
You will enjoy this unit. I have an L2550DT (29 horsepower) about a 1984 model and have used and abused this little guy and it comes back for more every day. It now has a little over 5100 hours but runs very well and uses no oil. Spent the day on it dragging out about 5 of about 40 acres of pasture with a 10' harrow with a 10' 10" I beam on it for weight (The harrow by itself is heavier than the loader can lift), put on a two bottom plow and cut a ditch and removed the dirt with loader.
Your tractor will last you a long time with a little regular preventive maintenance. I grease mine regularly (looks greasy and gross though but I use it and do not go in parades) and change the oil and filter every 100 hours like clockwork and the hydraulic fluid and filter every 750 hours. I suspect yours has the "pusher" fan as mine does so knowing how the clean the radiator screen is a good thing to know. Replaced the loader bucket a couple years ago as it was way too bent and front edge was torn up badly and I could not easily scrape out the barn.
60in Bucket Skid Steer Attachment (A61567)
60in Bucket Skid...
UNUSED KJ 20'X30' METAL GARAGE (A62131)
UNUSED KJ 20'X30'...
UNUSED SWICT 78" QUICK ATTACH BUCKET (A62130)
UNUSED SWICT 78"...
*Selling at Royal Auction Tampa, FL Location* (A59228)
*Selling at Royal...
2011 Ford F-550 4x4 Chassis Truck, VIN # 1FD0X5HT3BEC46890 (A61165)
2011 Ford F-550...
20 Yard Dumper (A61166)
20 Yard Dumper...
