Rear Finish Mower How do we change out he mower blades?
   / How do we change out he mower blades? #11
How many folks do a proper job of balancing?:D
   / How do we change out he mower blades? #12
I sharpen the blades on my Scag ZTR about every 10-15 hours and never balance them. You can balance them but they won't stay balanced anyway, so what's the point?
   / How do we change out he mower blades? #13
Because they won't remain balanced, (in theory) is not reason to not balance them to begin with; especially if you run 3 blades or more like my Wildcat does. One thing is for sure if you don't start with balanced blades they won't balance themselves over time.
   / How do we change out he mower blades? #14
I take my tractor with FEL and chain the front axle of the mower and stand it vertical to remove the blades. Leather glove to hold onto the blade and impact gun to remove the bolts. 5 minutes tops to remove all three blades, then into my vise to sharpen them with a 5" grinder with Tiger Paw sanding disc. I check balance by placing the blade on one of the sharpened edges of another blade with it centered in the bolt hole. Most times it balances without need to remove more metal, but I try to remove the same amount of material from each blade when sharpening. Then reninstall the blades and lower the FEL back down, unhook the chains and finished. I always wait a few minutes for all the oil to settle back before cranking up the mower.
Safety police might complain about working under a raised FEL, however I am really not under the FEL but under the mower which is completely vertical and in front of the FEl. I dont see this as a safety hazard worth considering due to the billion to 1 chance of a hydraulic hose failure causing the FEL to fail.
   / How do we change out he mower blades? #15
Gary,
I use a hacksaw blade in my vise to balance the blades on much the way you are doing.
Balancing the blades helps with bearing life and keeps the deck running smoothly. Sharp blades that are balanced yield a better cut imo.
   / How do we change out he mower blades? #16
I stick a pencil through the bolt hole to balance. If it doesn't spin to one side, I call it close enough. Is that a good enough way to balance? I'm envisioning you guys laying it flat on a blade or or hacksaw blade. Is that what you are doing?
   / How do we change out he mower blades? #17
I have one of those pyramid cones that have different grooves for different sized blade holes. Place the blade over the cone and it becomes easy to tell if the blade is balanced or if one side is heavier than the other.
MoKelly
   / How do we change out he mower blades? #18
That's the way I get to my blades also.
I was the operator of a forklift when the chain broke and a second time when a hose ruptured. Watching the forks drop and my load spilling was etched into my memory. I give gravity a whole bunch of respect because of that.
   / How do we change out he mower blades? #19
To remove mower blades, I usually find a place to wedge a 2x4 between the blade and the guard, so that the blade doesn't move, and then the bolt usually comes out pretty easily.
   / How do we change out he mower blades? #20
Gary,
And blades that are balanced and sharp yield a better cut while using less fuel due to the *drag coefficient on the spinning blade/bearings, etc.
*I made up the last part, because it sounds real enough....
2006 FORD F750 XLT SUPER DUTY SERVICE TRUCK (A51247)
2006 FORD F750 XLT...
2015 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A53422)
2015 Chevrolet...
2023 Chevrolet 1500 Silverado Z71 Crew Cab Pick-Up Truck (A55852)
2023 Chevrolet...
2011 CIRCLE M 32 FOOT GOOSENECK (A53843)
2011 CIRCLE M 32...
WACKER NEUSON (A55745)
2016 MACK CXU613 MID-ROOF SLEEPER (A55745)
2016 MACK CXU613...
