john deere 455 lawn tractor wont start
   / john deere 455 lawn tractor wont start #1
jgreen1997
texas
john deere 455
bogged down and died while i was mowing now it wont start back up. it just turns over and ever so often it puffs black smoke.
   / john deere 455 lawn tractor wont start #4
Key on do you hear the loud click of the fuel solenoid and the whir of the little electric pump?
Yes sir I hear both. And i put fresh diesel tank just to make sure.
The reason it bogged down and died is because I ran over a cable an it got wrapped around the blades and died.
   / john deere 455 lawn tractor wont start #7
So you may have deck/spindle problems, but now the engine will not start back? Humm...
Hopefully you disengaged all the PTO stuff. Seat, brake, reverse switch, or whatever is required to start it.
Have you checked all the fuses?
   / john deere 455 lawn tractor wont start #8
How did you finally solve this problem? I have kind of the same thing (ran over a t-shirt). I've pulled the deck but it barely turns over.
2017 Nissan Versa SV Sedan (A53424)
2017 Nissan Versa...
UNUSED WOLVERINE GB-11-72W 72" HYD GRAPPLE BUCKET (A54757)
UNUSED WOLVERINE...
High Lift Ratcheting Off Road Utility Farm Jack (A55787)
High Lift...
2007 Ford E-150 Cargo Van (A55788)
2007 Ford E-150...
2011 SHOP BUILT FLARE STACK (A53843)
2011 SHOP BUILT...
(APPROX 104) 2X4X10 PINE LUMBER (A54756)
(APPROX 104)...
